Full power + turning over and no start
Searched but didn't find a similar problem. I took my car out of storage Sunday. Started first shot after being outside all winter. Started again later and I drove 10km. Parked it in my garage for a day. This morning I go to start and it just sits there turning over and over. Battery is full power, I hear the fuel injectors engage when I turn the key and gas is full. I tried pumping the gas. I left it outside all day in the sun. What could be the problem? Condensation?
I had the same issue and i fixed it, it most likely is the same problem you are having , bad transmission ground, i replaced my strap made it longer and went right to the battery ground, you dont have to do this, but what you can is take it off and send off all the rust and dirt buit up over time and the paint off on the rail of the car since it's painted this will fix it, im sure its the ground strap
