Replacement for greddy td04 19t turbo??
Old Apr 14, 2009 | 12:58 PM
khmoe's Avatar
Default Replacement for greddy td04 19t turbo??
Hello, my bearings went on my greddy td04 19t turbo, i bought the repair kit, but when i tried to open it today the shaft snapped
No i need a replacement that will fit my greddy td04 19t that came with the kit on my civic 1996 ex coupe.
What ar values can i use? motor is stock, but i can tune my ecu and i i have a wideband, i only need a new turbo that works good. The greddy turbo went because i got water into the oil. new block and top so problem is solved.
The greddy turbo lasted 6 months so if i can get a cheap ebay turbo to fit i would be happy
Please help me and do not flame me.
Some options that i think will fit, but are they ok for my d16?:
http://cgi.ebay.com/ebaymotors/GT28R...Q5fAccessories
and:
http://cgi.ebay.com/ebaymotors/GT28-...Q5fAccessories
Old Apr 14, 2009 | 03:19 PM
TheShodan's Avatar
Moderator
Default Re: Replacement for greddy td04 19t turbo??
That is a TD04-19T Mitsu/garrett hybrid. Anything that uses a T25 flange/downpipe flange. Mainly the T2 flanged, Garrett ball-bearing series will work.
Old Apr 14, 2009 | 06:30 PM
NLR808's Avatar
http://www.boostplanet.com/services.htm they did the work on my greddy turbo a few years back had them put in a 20g compressor wheel
Old Apr 14, 2009 | 06:59 PM
TheShodan's Avatar
Moderator
Hell, we do that now on occasion for the Greddy Kits on 350z
Old Apr 14, 2009 | 10:25 PM
khmoe's Avatar
is there space for the gt28rs turbo on the greddy manifold?
will it work good on a orginal d16?
Hope i can twist it so i get a better angel on the outlet on the compressor side. on the greddy turbo it is 180 degrees different than the exhaust.
Old Apr 14, 2009 | 11:27 PM
TheShodan's Avatar
Moderator
Yes, but you'll need to change feed and return lines from the Greddy kit. Don't forget the water lines and .035" restrictor too.
Old Apr 15, 2009 | 02:20 AM
khmoe's Avatar
thanks for the reply.
found out that the gt28rs was expensive.
can i use a gt2860 (ebay version) and a new oil feed/return kit?
RWD_DC2
Apr 8, 2012 07:37 AM
974drgs
Apr 27, 2004 08:23 PM
