Clutch grinds
Old Apr 14, 2009 | 07:04 AM
MIGPA26's Avatar
Default Clutch grinds
When im driving normal clutch is fine no problems at all..
But when im the peddle to the metal and drving aggresive, it grinds when ingauging into gears??
What can fix this??
Old Apr 14, 2009 | 07:09 AM
sirtef9's Avatar
Default Re: Clutch grinds
Transmissions going to **** from abuse?
Old Apr 14, 2009 | 07:41 AM
89s1's Avatar
Syncros in the trans are wearing.
Try a 50-50 mix of gm syncromesh trans fluid and regular honda MTF. See if it makes it any better.
syncromesh is penicillin for trannies.
Old Apr 14, 2009 | 07:50 AM
puertoricanboy90's Avatar
Originally Posted by 89s1
Try a 50-50 mix of gm syncromesh trans fluid and regular honda MTF. See if it makes it any better.syncromesh is penicillin for trannies.
I know that the syncros for gear 2 on my tranny are going bad. How easy it is to rectify this manually to ensure the longevity of my trans? I've been told one can grind them down with a file and that will help. I know I could take it to a shop, but would rather glean knowledge from the possible learning experience. Any help would be great.
Old Apr 14, 2009 | 07:56 AM
Black4thgenEF's Avatar
If you're going to open the transmission anyway, you might as well just replace them. I wouldn't recommend it as a first job to try on your car though. If you are mechanically inclined, you could probably follow a manual.
Old Apr 14, 2009 | 08:53 AM
EL Vap133's Avatar
Did you just get that tranny and did it just start doing this? Sounds like a synchros problem to me.
Old Apr 14, 2009 | 11:12 AM
I have done engine rebuilds before, with my uncle and one on a ford windstar by myself. I replaced all the internal components etc. So, I would like to claim some credit towards being mechanically inclined. And no, the issue has gone on for a little while now (maybe 4 months and i've owned the car 9 months), so I was wanting to take care of the synchros now before they damage other transmission components. Where would i be able to find a manual/guide for replacing synchros on an 88 CRX Si? Thanks.
Old Apr 15, 2009 | 07:09 AM
MIGPA26's Avatar
I will try the 50-50 mix of the tranny fluids.. Daily driving is fine only when im on the pedal racing it grinds.. Might be me.. Also i have a short shifter which i hear are hard on synchos..
Thanks for help..
Old Apr 15, 2009 | 07:20 AM
MIGPA26's Avatar
how much fits about 1 quart correct??
Old Apr 15, 2009 | 07:44 AM
sirtef9's Avatar
2.5 quarts
Old Apr 15, 2009 | 08:28 AM
EL Vap133's Avatar
Thanks for help..
It is definitely your synchros then!
Old Apr 15, 2009 | 08:31 AM
mikej94civex's Avatar
not your clutch bro, its sycros! i had that problem with my old accord, it's from the abuse. U can try bleeding the clutch and even changing the gear oil but if it's sycros then u need a new tranny, rebuilt ones r too much $$$
Old Apr 15, 2009 | 12:52 PM
Aristotle's Avatar
Use 10w-30. Thats what I've been using for about 6 years now.
Old Apr 16, 2009 | 06:46 PM
MIGPA26's Avatar
THANKS EVERYONE!!!! I put in 2 quarts of synchomesh, and i can already tell it was smoother.. got on it and it didnt grind at all.....
Old Apr 17, 2009 | 12:55 PM
MIGPA26's Avatar
I was thinking when i installed the tranny i only put in about 1.5 quarts of oil, now it has 2 quarts of synchomesh. You guys stated it can hold 2.5 quarts.. would it be wise to add the other .5 quarts..
Could it of grinded because of the lack of tranny fluid (only had 1.5 quarts) ??
Thanks again for everyones help...
dirtmcgirt79
Sep 12, 2008 07:57 AM
misoshiru_akira
Feb 26, 2007 06:29 PM
SlimBB4
Sep 8, 2005 05:09 AM
reeder321
12
Dec 31, 2003 07:29 AM
tilt
Oct 7, 2002 01:22 PM
