WTB prelude b-series crank!!
ok i got an 95mm prelude crank (old b20) and it's junk
..so far 2 kids have flaked and i need one asap.... if not i'm prob just gonna get the eagle 95mm light weight.. problem is i don't have much money left
and i would like to make a couple passes this year!!
help a brother out!!
i have one....but i'd hafta check to see if its good...if you could get me some specs on the main and rod journals...hell i have an almost complete motor,,,,what else do you want?
it's has to be a 2.0 si or 2.05 si (88-91).... the carb crank is different
how many miles on it??? here's the spec's///
main journal diameter #1,2,4 and 5 = 54.976-55.000
main journal diameter #3 = 54.970-54.994
taper/out of round , main journal = 0.005-0.010 max
rod journal diameter = 47.976-48.000
Don't you hafta machine it to fit the Regular B-Series Journals anyways?
Who cares if the are alittle beat up or high-mileage...as long as there is no cracks.
Suprdave
Suprdave
Yea, why are you tossing that crank? Just use oversized bearings, and machine the crank.
No factory b-series is more than 95mm.
i know 95mm is the largest factory crank but if anyone has a real stroker crank i'd like to buy it!!
