engine rotates but will not start
Old Apr 13, 2009 | 11:39 PM
cftb16600's Avatar
Default engine rotates but will not start
90 CRX HF engine rotates but will not start or try to start any suggestions????
Old Apr 13, 2009 | 11:42 PM
exz0n-.-'s Avatar
Default Re: engine rotates but will not start
check your ecu
Old Apr 14, 2009 | 07:33 AM
Black4thgenEF's Avatar
Has the engine run in the car before? Did it die while you were driving it? Has it had any similar problems before? Are you getting spark and/or fuel?
Old Apr 14, 2009 | 08:40 AM
SquirtleSquadEf9's Avatar
does it turn over faster than usual?if so check ur timing belt...check the wires running to the distributor....o and try to push start it see if it works if it starts and runs for a while it will eliminate fuel and spark.....
Old Apr 16, 2009 | 11:25 AM
Maverick's Avatar
Team Purple
check the basics;
air
fuel
spark
post back what you find.
Old Apr 16, 2009 | 11:38 AM
S2Integra's Avatar
Distributor rotor, cap, or coil, or blown ign fuse (15amp)
Old Apr 16, 2009 | 12:15 PM
jdm27ef's Avatar
check cam gear it might be loose happen to me tight it and fix your timing if that doesnt work try what the other guys saying here.. ^^
Old Apr 16, 2009 | 08:52 PM
so have u tried anyof these things??
Old Apr 17, 2009 | 04:38 AM
xaine's Avatar
the magic eight ball says its your head gasket. LOL
you really, did not give enough information to have some one help you.
Old Apr 17, 2009 | 09:52 AM
I dont think this guy wants his car to work hahahhahaha
Felipe_Rdz
May 8, 2013 02:27 PM
tikishow
Feb 28, 2007 08:52 AM
LoudLX
Nov 8, 2004 05:17 PM
billyzakkus
Nov 17, 2003 07:10 AM
BLuDoHcReX
11
Feb 5, 2003 05:32 PM
