Dried up paint in gun? How do u clean it?
Old Apr 13, 2009 | 09:05 PM
aznboi_2's Avatar
Default Dried up paint in gun? How do u clean it?
Yea theres dried up paint in my gun i soaked it but it wont come off? is there a special solution i have to used?
Old Apr 13, 2009 | 09:11 PM
gsrturboda's Avatar
Default Re: Dried up paint in gun? How do u clean it?
tried using aircraft remover, or take it all apart, and let it soak in thinner for a while, not overnight cause it will cause the seal to get worn out faster.
Old Apr 13, 2009 | 11:29 PM
iwanttokillgod's Avatar
acetone
Old Apr 14, 2009 | 02:11 PM
shocker911's Avatar
there is stuff called naked gun i dnt know who makes it i got it at my paint supply store and the stuff worked really well
Old Apr 14, 2009 | 03:38 PM
HighRevn's Avatar
Go to your local jobber and get spray gun cleaner, be careful when using it cause its acid based. After soaking it for awhile rinse off with water then with laquer thinner. Youll have a brand new gun.
Old Apr 15, 2009 | 08:37 PM
crxscibo's Avatar
New User
take apart soak in thinners then rub with scotch brite or steel wool
Old Apr 17, 2009 | 06:08 PM
j_bizach's Avatar
uhh yeah dont use scotch bite or steel wool good way to mess up a gun. x2 on the naked gun good nasty stuff just make sure to rinse well.
steveharrmr23
Nov 15, 2008 09:24 PM
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
yuning83
Honda Civic (2006 - 2015)
Jun 25, 2007 04:05 PM
Andy R
Welding / Fabrication
May 19, 2007 08:17 PM
