B16B with LS crank and...
Old Apr 13, 2009 | 06:38 PM
PhatwhipsJDMkits's Avatar
Default B16B with LS crank and...
so currently have a b16b in my DD hatch and thinkin bout rebuilding it. i already have a LS short block. researched and found that this crank and stock length robs in ctr block stroke to 1.9 liters. this is my daily so i think im gonna stay away from forged internals. so running LS crank Stock LS Rods with ARP bolts and what pistons?? ITR, CTR, LS.....what? also would like to have around the same C/R as we dont have any higher than 91octane here in CO
Old Apr 13, 2009 | 06:43 PM
C_Rock77's Avatar
Default Re: B16B with LS crank and...
www.zealautowerks.com has a good compression ratio calculator. Use it to mix and match parts to get the CR you want.
If it were me, I'd use an Eagle Rod and something like an RS Machines cast piston. LS rods are just kinda wimpy, and I would prefer not to use them.
Old Apr 13, 2009 | 07:02 PM
alright thanks also lookin into a bit more with LS crank you have to remove the oil squirters which would be bad running stock rods correct?
Old Mar 29, 2012 | 03:50 PM
mattsir1999's Avatar
does the stroke realy change when you instal a b18 crank into a b16b block with the b16b head
Old Mar 29, 2012 | 04:03 PM
doood's Avatar
been there done that
yes
Old Mar 30, 2012 | 06:27 AM
kyden's Avatar
an ls crank in it would just make it 1.8. if you went to 84mm bore it would be a 2.0
haas480
Sep 1, 2009 04:09 AM
GSR_hatch936
Apr 30, 2008 06:48 PM
jordan2305
Dec 11, 2007 04:47 PM
EGcivicvtec
Feb 13, 2006 09:54 AM
