Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 wind noise
Old Apr 13, 2009 | 06:13 PM
msaeger's Avatar
Default 2002 wind noise
I have a 4 door 2002 civic and am getting loud wind noise from the drivers side. I don't feel any air coming through and I tried putting tape over the seam between the door and the car body on the outside with no change in the noise.
Any suggestions on what to try ?
Old Apr 13, 2009 | 07:49 PM
toyomatt84's Avatar
Sanji
Default Re: 2002 wind noise
It might be coming from your door handle.
Old Apr 13, 2009 | 08:22 PM
lowlife9's Avatar
you could turn up the radio.
Old Apr 13, 2009 | 09:16 PM
SoCalian_SD's Avatar
Civics are noisey...get used to it.
Old Apr 13, 2009 | 09:21 PM
JDM02em2's Avatar
hahah, x2 radio takes care of all noises.
Old Apr 13, 2009 | 10:24 PM
DynastyRacer22's Avatar
that happened to me before it was because the door weather seal part was torn and air went through it try checking that or put more pressure on your driver side window
Old Apr 14, 2009 | 04:21 PM
msaeger's Avatar
How would I see if it's the door handle ? put tape over it ?
Old Apr 14, 2009 | 07:17 PM
sure if u want but its not hard to drive and listen to where its coming from it can be anything
Old May 11, 2012 | 03:55 PM
me, CIVIC05EX's Avatar
I get this noise when i'm doing >40mph, right above my ears and its annoying
any suggestions?
Old May 12, 2012 | 09:26 PM
EM2abe's Avatar
honestly, its the door seam. there isnt a proper seal between the rubber door seal and the door jam. this happened to me when i once locked my key in my car and i had to have a tow truck driver get it open for me. they used a wedge and a pump wedge to slightly open the door enough to slide a metal rod and press the unlock button. the pump wedge bends the doors frame around the window a little. you kinda just have to bend it back. just grab the top corner of your door while standing on the inner side of the door and while holding the door open with your leg or something, just pull the corner towards you. dont pull too hard. just pull hard enough to fix it. drive around a bit and see if that fixes it. kind of a silly way to fix something but hell, it worked for me.
bonnyman
Jan 25, 2007 10:13 PM
loup05
May 22, 2006 08:47 PM
ThisLittleSleepeR
Nov 15, 2004 09:40 PM
CaTiRo
Mar 25, 2004 08:49 PM
