H22a1 to H22a swap questions
Old Apr 13, 2009 | 01:45 PM
2mchbst's Avatar
Default H22a1 to H22a swap questions
I have a 94 accord ex now with a H22a1 swap 5 speed, i will be swaping out everything for a jdm H22a motor and tranny, what parts do i need swap the off the H22a1 to the H22a? Also i have an external coil setup now on my H22a1 motor and vtec does not work at the moment, does anyone have a link they can send me as far as wiring up the vtec the right way? I will be installing a skunk 2 intake manifold as well.
Old Apr 13, 2009 | 02:14 PM
Peeonu25's Avatar
Default Re: H22a1 to H22a swap questions
get a manual
you shouldnt need any parts, h22a and h22a1 is the same motor, only real difference if internal/external coil.
it should drop right in, use the same exact plugs etc.
Old Apr 13, 2009 | 03:17 PM
alkoholikwun's Avatar
tell me your not just swapping it out for a similar but JDM motor?
you can wire vtec wires straight from vtec solenoid on motor (near dizzy) to the ECU pin outs, only 2 wires.
Old Apr 13, 2009 | 04:28 PM
2mchbst's Avatar
no my H22a1 has a about 95k on it and has a slight crack in the block right below where the head and block meet and leaks coolant from time to time.
Rzinzow01
Oct 16, 2017 05:48 AM
B-HuTcHiE
Nov 24, 2004 01:55 PM
crxtreme27
Jul 19, 2002 06:25 PM
freakie
Jun 7, 2002 02:19 PM
