FS Lexus SC300 (Toyota Soarer) MUST SEE!
SOLD
I'm posting up a clean Lexus SC300, or Toyota Soarer to some, for my friend. Here is the details from his original post. Please feel free to view, read, and bump. PM, or email me at dukgen118@gmail.com with questions, or to set up an appointment. Car is located in Orange County. No Random Test Drives, Only Serious Inquiry w/ a reasonable down payment....
After many months of consideration, I am putting my car up for sale...
I am proud to say it is one of the cleanest SC in this forum, ALL modifiations were done at PlatinumVIP. This car is all show and all go, however, never see past 9lb of boost(no boost controller) so you know the engine is healthy. All you need is to install a boost controller and go for another tune, you will be making 450+ rwhp. New paint job 2 years ago and single turbo conversion with all new gaskets in 12/2007.
Car is mostly driven from home to work (20 miles) and from home to PlatinumVIP on weekends
Chassis: 1992
Chassis Mileage: 150,xxx+
Engine Mileage: 55,xxx+
Clean Title: CarFax Available Upon Request
Engine Modification:
1JZ-GTE
ARP HeadStuds
Unorthodox Pulley Sets: Crank, Power Steering, Water Pump, Altenator
Garrett T4 .61 a/r w/turbo blanket
4" Intake
SS Exhaust Manifold
HKS 40mm External Wastegate w/ 9lb spring
3" SS downpipe /wrapped in heat wrap
Innovative Wide Band O2 sensor w/display gauge
3" custom mid-pipe w/resonator (no cat)
Blitz Nur-Spec Cat-Back Single Exit Exhaust
Aeromotive FPR w/ SS fuel line
USDM 2JZGTE 550cc injectors
Power Enterprise Timing Belt
Power Enterprise Serpentine Belt
Koyo All Aluminum Radiator w/ 2 electric fans
Walboro 255lph In-Take Fuel Pump
Stinger EMS: Full Stand Alone Engine Management w/Software and Tuned Maps with Laptop Connector
(Engine will be flushed with new synthetic oil and all fluids top off)
Transmission Modifications:
Auto --> 5 Speed Conversion
R154 out of a MK3
TRD Stage 2 Clutch w/ Pressure Plate
All new hardwares from Toyota Dealership: Flywheel bolts, Clutch fork, Throw-out bearings, etc...
MK4 Auto LSD
C's Short Shifter
(Shifter housing was extended by Supraman from Supraforums in San Diego)
Exterior Modifications:
Custom Silver Pearl Off-White by PlatinumVIP
97+ Front Conversion w/ Big-Win Lip
Vertex-style side lip kit
Vertex-style rear lip kit w/modification to single exhaust opening
Sun visor
(One of the side kit got a small crack, and front lip kit has the usual rock chips)
Suspension Modifications:
Cusco Zero 2 Coilover System
TRD Strut Tower Bar
Battle Version Rear Toe Links
Battle Version Rear Traction Links
Daizen front upper control arm bushings
Daizen front lower control arm bushings
Daizen Steering Rack Bushings
(Since all bushings and links has been changed, the ride quality is tight)
Wheels and Brakes Modifications:
J-Line 10RL2
Front: 19x8 +19 wrapped in Toyo T1R (5 months new)
Rear: 19x10 +15 wrapped in Toyo T1R (2 months new)
(Have 2 Extra Rear Wheels for Spare, Total 6 Wheels)
'95 LS400 Front Calipers w/ Rotora slotted rotors (45%) Have new pads ready
'94 Supra MK4 Rear Calipers w/stock rotors (60%)
Interior Modification:
Nardi Steering Wheel
Front Seats Were Rewrapped 3 years ago
All Wood-Grain Interior Pieces are Painted Black.
Pioneer Navigation AVIC-D2 w/IPOD connection
10" Eclipse w/Kenwood Amp (replaces the stock subwoofer)
Optima Red Top Battery
The car is reliable and fun to drive. Oil change every 3k ~ 5k of driving and always synthetic: Eneos, Torco, Royal Purple, Redline or Mobile 1. Only use 91 Octane. It is tuned for mid-high range powers, so its very fun and responsive on the freeway. However, the car has not see more than 9lbs of boost since the Garrett T4 replaced the stock twins, and I did not have the chance to install a boost controller. The car has pretty much every mods available for a SC and all it needs is a boost controller to turn up boost and a re-tune to unleash the true potential of this turbo. I hate to let this car go, but I only have 1 garage and I currently have 3 cars. However, I am not in a hurry to sell this car.
I am asking $19,500 and will entertain offers, no low ballers please...
Cons: AC Works, but needs a recharge, 2 Interior pieces has leather rips: Passenger Window Frame and Center Arm Rest. Front lip has rock chips, one of the side kit has a crack. Speedometer does no work...will have to use Pioneer AVIC D2's Vehicle Dynamic Option for Speed. RPM Do Work!
Chassis: 1992
1JZ-GTE
ARP HeadStuds
4" Intake
SS Exhaust Manifold
R154 out of a MK3
MK4 Auto LSD
C's Short Shifter
Sun visor
TRD Strut Tower Bar
J-Line 10RL2
jDMJeRk
Mar 6, 2013 06:03 PM
mikaleg6
Apr 23, 2009 07:29 AM
