95 accord h22a accord no spark
Old Apr 13, 2009 | 01:33 PM
Timmay's Avatar
Default 95 accord h22a accord no spark
jdm ob1 motor
95 accord harness
p13
is there something different on the h22a harness that has to be changed? i know that the accord has extrnal coil and the h22a has internal. I cant seem to find any charts of what is needed to be done
would appreciate some help
Old Apr 13, 2009 | 02:03 PM
Peeonu25's Avatar
Default Re: 95 accord h22a accord no spark
get a usdm dizzy from an h22a1 a4 or a h23
Old Apr 13, 2009 | 02:08 PM
Timmay's Avatar
so after that i should be good to go?
also then i would need to use the accord coil right?
Old Apr 13, 2009 | 02:15 PM
Peeonu25's Avatar
well you could wire up the internal dizzy, its just as easy. i scrapped the accord coil and bought an msd coil.
Old Apr 13, 2009 | 02:26 PM
Timmay's Avatar
on the accord coil plug there is 3 wires going into it. which of those 2 wires would need to goto the coil in the JDM h22a distributor?
Old Apr 13, 2009 | 02:49 PM
Peeonu25's Avatar
none.
im not at home right now so i cant go and look.
black yellow to the positive then the negative is ran from the dizzy. i wont be home until later tonight, my old roomates band is playing in seattle, im check them out tonight.
Old Apr 13, 2009 | 02:54 PM
Timmay's Avatar
thanks for your help. ill mess around with that
Old Apr 13, 2009 | 03:03 PM
Peeonu25's Avatar
sorry i couldnt be of more help, im having a crazy brain fart right now.
Old Apr 13, 2009 | 08:06 PM
Timmay's Avatar
well i ran a wire from the black/yellow where the accord coil is direct to the + of the h22a coil and it starts . but either my wire isnt good enough or i have a weak distributor cause its starting to be very choppy and cuts out alot
Old Apr 14, 2009 | 08:07 PM
BBallz24's Avatar
What I did too
Old Apr 14, 2009 | 10:52 PM
f20b jones's Avatar
All you have to do is but connect the yellow wire and the black and yellow wire at the coil together and plug the internal coil distributer up and it will work the other wire going to the coil is just a input wire coming out of the external coil distributor which the internal coil distributor does not have so its just a dead wire once you change distributors.
DillyD
Jan 17, 2010 07:19 PM
D21X
Sep 15, 2003 09:05 AM
WNYAccordLX
Mar 22, 2003 06:12 AM
