main relay constant clicking
Old Apr 13, 2009 | 12:21 PM
boostinh2x's Avatar
Default main relay constant clicking
Doing this on my blackberry so its more efficient to post up rather than search. Just swapped a d16a6 into my 91 dx but using the d15 pgm fi. Main relay is clicking constantly. Do I need a new relay? Any other ideas? Thanks
Old Apr 13, 2009 | 03:22 PM
redflaredcrx90's Avatar
Default Re: main relay constant clicking
is the car running what ecu are you running
Old Apr 13, 2009 | 04:07 PM
GSR CRX's Avatar
did you ground all the ground wires from the engine to the chassis.
Old Apr 13, 2009 | 04:37 PM
detuned's Avatar
i'd say do the mpfi conversion and grab a pm6. did it to my HF and the relay works fine. like GSR said, check the grounds and maybe you need to do the relay fix (aka solder the busted points).
sd619jef9
17
Feb 5, 2017 08:20 AM
turbocivic1984
Jun 29, 2008 09:59 AM
broken crx
Aug 1, 2006 03:02 AM
