need help with 2 things Thanks
Old Apr 13, 2009 | 09:03 AM
streetsold6teeny8's Avatar
Default need help with 2 things Thanks
Which lower radiator hose do you guys use with a b series motor.
Also where can i find the battery tie down for the stock location of the battery.. ebay has but they look short since its held vertically rather than horizontal as most hondas.
Thanks in advance
Old Apr 13, 2009 | 11:13 AM
ridgeapd's Avatar
Default Re: need help with 2 things Thanks
Go to a junk yard for the battery tie down.
I think I used a Lower radiator hose from a 90-93 integra in my CRX. Don't quote me on that.
Old Apr 13, 2009 | 11:16 AM
h22ed6's Avatar
which b swap do you have?
Old Apr 13, 2009 | 12:26 PM
Grnnt4's Avatar
I used '94 and up del sol vtec upper and lower hoses when I replaced the radiator in my b16 crx and they fit great, if that helps...
k20rex's Avatar
your stock hose should work fine
Old Apr 13, 2009 | 01:25 PM
i got a gsr b18c1 i figured a Da would fit... motor came out of a eg so i know the top one works....
as far as the tie down i do go occasionally to the junkyard but they arnt there the tie downs are gone or idk..
any ideas as far as what to do to hold it down... properly and good looking im restoring (not big money ballin restore but nonetheless its more than a normal paint/ swap build)the car..
whiskeypiss
Oct 9, 2007 05:05 PM
drshottest718
Apr 27, 2006 05:30 PM
Touge Tuning
Oct 17, 2005 07:23 PM
c_buz
10
Dec 21, 2004 07:21 AM
