So I decided to build a flowbench
Old Apr 12, 2009 | 11:24 PM
leshok's Avatar
Default So I decided to build a flowbench
Well I have been working over cylinder heads for quite a long time and was tired of being held back because I lacked the tooling to measure airflow (quality as well as quantity). I wanted to have the ability to manipulate airflow and also have the ability to measure and record data for further testing . So I decided to build a flow bench for my hobby shop. It will be capable of 450cfm-460cfm (Capacity can be increased with addition of motors, but it should be sufficient for the time being). Current orifice plate is capable of 335cfm. It is measured with a Digital manometer that consists of three pressure pick ups: One for static pressure (For my Velocity probe), Second static pressure pick up and a differential pressure pick up to make calculations more simplistic.
I have successfully flowed a d16z6 and H22a head so far. I have also flowed throttle bodies, intake manifolds, high flow cats and the bench has been great.
Send me some stuff to test!
Here is one of the only pictures I have currently. Let me know what you guys think.
Old Apr 12, 2009 | 11:55 PM
Combustion Contraption's Avatar
Default Re: So I decided to build a flowbench
Looks good. Make sure to use a radius entry when flowing inlet, and some sort of tubing when flowing EXH.
Old Apr 13, 2009 | 08:52 AM
leshok's Avatar
It has already been done. Picture was just a mock up. I need to get some action shots. Thanks for the input!
Old Apr 13, 2009 | 08:59 AM
leshok's Avatar
I forgot to mention. I will be receiving my pitot tubes either tomorrow or Wednesday. This will give me the chance to map ports and measure velocity.
The swirl and tumble meter is also in the works right now.
Old Apr 13, 2009 | 11:14 AM
fatboy1185's Avatar
Big Cat
interested in seeing some flow numbers for h22 head that you have worked over
Old Apr 13, 2009 | 11:23 AM
leshok's Avatar
Sure thing.
Old Apr 13, 2009 | 10:20 PM
leshok's Avatar
I put the head on the bench for you. Just cleaning up the castings I was able to get 280 cfm with stock valve size/valve angle. This is up from 272cfm I baselined it at. It has stock velocity rate, and minimal pressure drop. It is a nice head, and it has quite a bit to go still! HTH!
Old Apr 13, 2009 | 10:43 PM
h2bna motor's Avatar
http://www.flowperformance.com/system.html
I seen this befor.
Old Apr 14, 2009 | 12:22 AM
leshok's Avatar
Originally Posted by h2bna motor
Yea I have seen a few pvc pipes for $1000 too. I would be surprised to see a 120v shop vac pull any significant cfm at a "standard" depression.
Old Apr 14, 2009 | 06:17 AM
alterdcreations's Avatar
good info in the links non the less.
how much money did you invest in the project?
Old Apr 14, 2009 | 06:43 AM
BIGTUNA's Avatar
As always excellent work Leshok
Old Apr 14, 2009 | 09:12 AM
leshok's Avatar
Too much!
Thanks for the nice word tuna!
Old Apr 14, 2009 | 09:44 AM
flesh199's Avatar
good job buddy...great diy to say the least
Old Apr 14, 2009 | 10:01 AM
1.5Slowmatic's Avatar
cant wait to get my head flowed that im porting
Old Apr 14, 2009 | 10:07 AM
lohatch's Avatar
nice job man! i was going to build one a couple years ago but have one at work now. how much do you have into it if you dont mind me asking? you can PM me if you dont want to post it
Old Apr 15, 2009 | 03:53 PM
leshok's Avatar
Update: I got my Velocity probes in today. The bench is fully operational now.
I have had many cylinder heads on the bench so far. All with good results!
Now send me some things to flow test!
sdubfid
Welding / Fabrication
Nov 2, 2009 03:27 AM
De_tour
May 7, 2007 05:45 PM
Justin Olson
25
Jan 19, 2006 05:11 PM
EFSiR
Apr 1, 2005 03:15 PM
