the best plugs for B16a
right now im running bosch platinum 4 **** plugs
and im about to get a set of B16a2 NGK plugs.
is there a diff between the B16 plug wires and the LS plug wires.
whats the difference in the LS and B16 plug wires.
should i get the regular Vpower NGKs or the 4 **** Ngk'z my tuner said that 4 **** ngk's burn fuel better.
and for the jdm B16a i get 2000 civic si plugs?? , cuase i know for the motor every thing is compatible with the 90 tegg B18a and the B16a2 and for the cable trans 90-93 clutch stuff.
Im running some hks plugs on my b18, expensive but worth it. Difference between the wires is the rubber that slides onto the valve cover holes, its like putting d series wires on b series, its going to be lose
-2000 civic si fly wheels
-for cable trans
90-93 clutch kits ,disk pressure plates
if there is any thing else i missed let me know
NGK V-Powers are all you need. Anything more on a stock B16a is a waste of money.
A B16 wont run properly with LS plug wires. I think I went with 94 del sol VTEC wires.
in general, youre supposed to stick to the brand that matches the make of your car. so for example if you have a ford use autolite, bmws use bosch, etc....since we're interested in hondas, NGKs.
i've never heard that before. what about ford and motorcraft. i know autolite is ford factory, but..... what about crysler? i've used autolites in my jeep, and my civic. i've also used ngk in my 85 chevy small block truck. and my father in law uses champions in his 96 ford explorer. all with no issues. so what your saying...just....doesn't make sense to me.
if you have a b16 a use 92 -93 gsr spark plugs and wires they used the same head if you have an ob2 b16 head i think honda went to a plat. ngk plug if im not mistaken. i know 99 00 si use this plug from factory
meagainsttheworld
Mar 19, 2007 07:11 AM
Mike95lude
Sep 30, 2002 06:52 PM
spdster
Aug 15, 2001 11:51 AM
