B16A1 Secondary o2 Sensor Problem
Old Aug 15, 2002 | 06:29 AM
EF8_SiR's Avatar
Default B16A1 Secondary o2 Sensor Problem
So I'm cruising along and decide to downshift and throw into vtec. All of sudden I downshift, hit vtec and next thing u know my engines goes into safe mode and my AFC shows full out rich. I pull over, my idle is now sitting at 500 (usually at about 900). Open hood and I find my green o2 sensor wire snapped. I guess it was dangling from a hair line previously.
Now my question is, the green one being the JDM sensor/wiring, is it possible to put in another white one? I'm not looking to fix that wire. I wanna replace the whole thing, so is it possible?
Or if fixing is not an option, is it possible to wire everything so that both readings are taken off the white one?
Old Aug 15, 2002 | 07:00 AM
HybridFiend's Avatar
Default Re: B16A1 Secondary o2 Sensor Problem (EF8_SiR)
Some have luck with using the primeary O2 sensor into both inputs on the ECU, but some don't. Just depends on your application.
Old Aug 15, 2002 | 09:40 AM
Booger's_Rex's Avatar
Default Re: B16A1 Secondary o2 Sensor Problem (HybridFiend)
i have previously tried tapping both wires into the white one and it caused my car to back fire a lot so i just wired in both sensors the correct way and it ran fine
got_no_sol
Sep 26, 2016 08:26 AM
conguero
Nov 18, 2004 06:36 PM
Soled Out
Jan 6, 2003 04:24 PM
00-ITR-373
Jul 16, 2002 04:06 AM
HXMan
Apr 26, 2002 08:13 AM
