which one Tial 35 or 40 mm wastegate
Old Aug 15, 2002 | 06:29 AM
symba's Avatar
Default which one Tial 35 or 40 mm wastegate
setup:
SFP or Maxrev manifold
Greddy PE exhaust
2.5" dowpipe
t3t4e .48a/r turbine 60 trim
built bottom end
PNP head
venom intake manifold
550cc injectors
hondata 2b w/datalogger
goal is 300 - 350 whp
should I get the Tial 35 mm wastegate or go for the 40mm?
Old Aug 15, 2002 | 06:30 AM
KC GSR's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (symba)
I think you want the 35mm
Old Aug 15, 2002 | 06:35 AM
Elite Hatch's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (KC GSR)
Either one will be fine. But it seems as if the setup you are looking for the 35mm will be fine. Though Tial did come out with a new hybrid 35/40mm that uses a 35 flange but the 40 spring...BAD ***
Old Aug 15, 2002 | 07:27 AM
justagsr's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (Elite Hatch)
<~~~what I just got in the mail.
Old Aug 15, 2002 | 07:57 AM
Default Re: which one Tial 35 or 40 mm wastegate (justagsr)
How much did you pay I am looking to get one as well?
Old Aug 15, 2002 | 08:14 AM
AcuraFreak's Avatar
$219 SHIPPED for the .35mm on GroupBuyCenter.com
I want the .35/40 as well though !
Old Aug 15, 2002 | 08:24 AM
Brian_92GSR's Avatar
New User
Default Re: which one Tial 35 or 40 mm wastegate (AcuraFreak)
Viren (b18bturbo) usually has good deals on tial wastegates.
Old Aug 15, 2002 | 08:31 AM
ArizonaTurbo's Avatar
The Tial 35mm will be more than sufficient for your setup. You may want to look into swppingthe .48 A/R turbine housing for a .63 A/R housing if you are planning on making 300-350 whp. The .48 A/R turbine housing can not support those HP levels!
Old Aug 15, 2002 | 08:38 AM
symba's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (TurbochargedSER)
I was afraid of the turbine being on the small side. I can't afford to change anything now, I'll just wait until after all is said and done..Then change later...damn
Old Aug 15, 2002 | 08:41 AM
A turbine housing is only like $150.00, so you can upgrade it at anytime! See what you can do with the .48 A/R housing I am estimating that it will top out in the 275-285 HP range.
Old Aug 15, 2002 | 08:42 AM
b18bturbo's Avatar
if you guys are lookijg for WG let me know i have the tial 35mm std units for 216 and 236 for the high pressure units.
The tial 40mm as well in stock.
Old Aug 15, 2002 | 09:03 AM
Smashback's Avatar
That kinda blows since I paid $200 shipped for mine over a year ago!!
Old Aug 15, 2002 | 09:10 AM
AcuraFreak's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (mplex2000)
Does your mom know ?
Old Aug 15, 2002 | 09:13 AM
AcuraFreak's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (b18bturbo)
Hey your in or near Dall-A$$ ehh ? How about REAL Bomex Kits can you get them ? And you said .35/40 Tial you can get ?
Old Aug 15, 2002 | 09:14 AM
AcuraFreak's Avatar
Hey b18bturbo your shop in or near Dall-A$$ ehh ? How about REAL Bomex Kits can you get them ? And you said .35/40 Tial you can get ? I have a list for ya if the prices are right...
Thanks.
[Modified by AcuraFreak, 6:29 PM 8/15/2002]
Old Aug 15, 2002 | 10:12 AM
justagsr's Avatar
<~~~got the tial from Viren...
Old Aug 15, 2002 | 10:22 AM
93LSivic's Avatar
Sorry kinda OT but.....can you upgradde the standard 35mm to the HP 35mm by swapping out the spring. Or is the actual wastegate door larger and just use the same flange?
Old Aug 15, 2002 | 12:56 PM
b18bturbo's Avatar
Default Re: which one Tial 35 or 40 mm wastegate (93LSivic)
the actual difference is in the top not the bottom casting. The tops are actaul 40mm tops. thats the only difference.
DS1
Oct 16, 2002 06:21 AM
