Need help with engine question
Old Apr 12, 2009 | 03:21 PM
JdMJ0hnny's Avatar
Default Need help with engine question
im having coolent water leaking into my number 1 piston. i've resurfaced the head and changed the head gasket plenty of times, i was wondering if not torquing it to spec can cause the coolent to leak into the piston? oh yeah and the oil comes out milky everytime i drain it. and one more question, do i have to change gasket everytime the oil is milky? thanks happy easter everyone!
Old Apr 12, 2009 | 03:22 PM
JdMJ0hnny's Avatar
Default Re: Need help with engine question
bump for help
Old Apr 12, 2009 | 03:36 PM
sleepingciv's Avatar
yes not to torquing to spec will deff make it leak.
also could have a warped block surface or a cracked head.
put a fresh gasket in it tourqe to spec in correct order and do a leak down test before you start it
Old Apr 12, 2009 | 05:18 PM
JdMJ0hnny's Avatar
ok thanks whats a leak down test?
Old Apr 12, 2009 | 10:04 PM
aaronhume's Avatar
it checks to see how long the pressure lasts in the combustion chamber with intake and exhaust valves closed. if you resurfaced the head you need to resurface the block too... and if you are still having problems you must have something cracked. a leakdown test would help figure that part out before spending too much money.
EFSedanMan
Mar 6, 2010 12:58 PM
skUnK2jdm
Jan 30, 2007 05:36 AM
hondaboyz94si
Dec 10, 2005 06:13 PM
doublejz
10
Sep 27, 2005 09:06 PM
