b18 block b16 head ls-v Good for turbo ??
ok i have a b18a1 setup in my integra for turbo and b16a head, thinking of installing the b16a head on the block, will it be good for boost ??
whats better b18a1 block and head
or b18a1 block and b16a head ??
what do i have to do to fit b16a head onto a b18a1 block ?
Wow, is ls/vtec good .... nice.
Help for the search challenged -> https://honda-tech.com/forums/showth...ight=ls%2Fvtec
27pgs worth
27pgs worth
27pgs worth
27pgs worth
here my friend... this will help you to understand this kid a bit more and realize why he is asking such horrible questions. gotta take a look.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/my-all-motor-13-5-1-civic-eg-hatchback-178ish-ground-2546201/
ill leave the one off about vted fluid he needed to check.... yes i said it... vtec fluid.
https://honda-tech.com/forums/showthread.php?t=2546201
You owe me like 2min of my life back.
I think you should put it in your red EG so you can "smoke a GSR out the hole".
I also recommend changing your CR to 13.5:1. Should be good for about 178ish WHP!
Don't forget the stickers, either. Lots of them. They should be good for another 178, easy.
Brain909
23
Nov 29, 2009 10:38 AM
krysted9354
Apr 13, 2009 05:04 AM
