what rings do you run with your vitaras?
so i was checking the gap on my current 75.5mm vitara z6 build, and one of the top rings out of the box has a huge gap. it measured in at about .024". even the other top rings were still coming in at around .018-.019" which is larger than i wanted to go as the motor isnt gonna see much more than 250-300 hp. currently i just think im going to order a set of 76mm rings and file them down. is there a preferred brand? anyone run oem rings? i've got the local honda dealer less than a mile away.
