Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2002 Odyssey Brakes vibrating
Old Apr 11, 2009 | 05:54 PM
swag's Avatar
New User
Default 2002 Odyssey Brakes vibrating
Hi,
I replaced all 4 sets of brake pads on my 02 Odyssey. I did not machine any of the rotors. I used ceramic pads from NAPA that were pretty good quality.
Before replacing the pads I did not have any vibration when applying the brakes. With the new pads the car shakes like crazy every time I press on the pedal. It was not bad at first but now after a couple hundred miles it is very annoying.
Any suggestions on why this would be happening?
Thanks for any help.
Swag
Old Apr 11, 2009 | 08:09 PM
marmaladedad's Avatar
Default Re: 2002 Odyssey Brakes vibrating
Did you get the Odyssey's rotors checked since your installation of the brake pads? Seems like an easy thing for a shop to check for you. And if it's not the cause of the problem, you eliminate one variable.
Old Apr 12, 2009 | 06:57 AM
anngsr1's Avatar
if you install the brake pads properly, maybe your rotor is warp.
check the parallel of the rotor or have somebody resurface the rotor.
Old Apr 13, 2009 | 06:44 AM
aikimo's Avatar
New User
Hello.
As other folks have stated you either have warped rotors, or perhaps material build up on your rotors.. Take the van out and try 3-4 hard stops.. If the shaking goes away, then the issue was material buildup or glazing.. If not, then replace the rotors..
Regards
Mo
a.wax
Sep 15, 2007 06:53 PM
teggsr925
Mar 3, 2007 01:35 PM
Toneman14
Sep 23, 2005 08:29 AM
old_school_dohcvtec
Apr 30, 2005 07:47 AM
Lewie
Apr 13, 2005 05:44 PM
