vfac on 90 dx obdo?
I have a vfac just layin around well like 3 but 1 is in my 95 civic, one has a broken screen and yea besides the point. But I was wondering how I could wire in the vfac? I know I will not have the vtec features. But the tach would be nice and the throttle position and stuff. So does any one have the wiring diagram for the ecu? I need to know what wires are the igntion power, the ground, the tach/rpm signal, and the throttle signal. I belive the pressure signal as listed here on apexi is for the vtec part so no need for that. I just want to add some bling in my car and be orignal. http://www.apexi-usa.com/pdfWiring/21.pdf
flame suit is on. But maybe some one can help me.
thanks,
Wil
thanks,
Wil
Get the ecu pinout that shows the wiring differences from dx-si... I had one in a dpfi civic a long while back, and I seam to remember all the necessary wires being in the same spot on dx and si, and I just used the diagram for an 88-91 si.... But like I said, double check the diagram.
I figured they would all be the same. Only difference would be the 2 injector on the dx and std and si having 4. Its a dx dualport. Does any one know? I'm thinking I could use the tach wire to blue wire on dist. and power wires to the ign on and just ground the grounds. Any ideas? Ha I have a honda tattoo to.
Ok so I looked at a few online manuals and can not find the ecu wiring colors and codes for the life of me. I just need throttle position, tac/rpm signal, ign on and ground. what pins or colors are those?
thanks,
Wil
thanks,
Wil
so you are not trying to actually tune the afr? if that is the case, a junkyard ex will have an instrument cluster with a tach... that would save time, and then you could sell the vafc and have extra money.
Yes, I know that. But I'm not trying to spend money on stuff I already have. I'm not trying to tune anything. I want the vfac so when I park in bad spots in eugene I can unplug and walk away and it looks like a stock old person owned hatch. Dx with a tach... hmm... maybe something else.
