your thoughts on ls/vtec/turbo
Old Apr 11, 2009 | 09:47 AM
turbogenetic's Avatar
Default your thoughts on ls/vtec/turbo
i was thinking on going ls/vtech/turbo on my teg.
alot of people have been telling me about the unreliableness of this.
but my though is if its built right with good parts it should be fine right?
what do you think?
Old Apr 11, 2009 | 10:35 AM
HondaTom87's Avatar
Default Re: your thoughts on ls/vtech/turbo
first spell vtec right... lol
next anything is reliable if you build it right...
dont think of parts think of your goal...
what do you want to do with this motor?
Old Apr 11, 2009 | 11:05 AM
im just wanting somewhere over 250hp that i can drive as a dd that i can depend on.
Old Apr 11, 2009 | 11:07 AM
mrdeadman's Avatar
They let me pick
A turbo setup will get you over 250 reliably. You don't need lsv.
Old Apr 11, 2009 | 12:57 PM
that is true...
but ive already got a stock lsv in my car.
i was considering boosting it.
shouild i build the motor or go back to ls and boost it?
sorry im pretty new to the honda theme
Old Apr 11, 2009 | 01:25 PM
teggything's Avatar
well there is no stock lsvtec engine, but you can sell your vtec head and just have an ls turbo and get 250 easy. and you wouldnt have to pay that much for the turbo and ****. im going lsv n/a looking 4 200 whp when i done. but if money is not an issue for you then you can build the lsv turbo and as long as you do it right and dont rush the build it should hold up fine
Old Apr 11, 2009 | 01:26 PM
wade's Avatar
if you know this little, then you don't need to go off turbocharging your car. Just a honest word.
Old Apr 11, 2009 | 01:33 PM
HondaTom87's Avatar
well n/a is out if you want that much power...
yeah and what do you mean by stock ls/v? if I was you I would start pulling that motor apart asap and make sure it was built correctly. also find out what pistons are in there and that one piece of info could end up making you change your mind about your goals.
Old Apr 11, 2009 | 01:48 PM
thanks with the learning process wade.
when i say stock lsv i mean that it was converted and thats it.
theres no other aftermarket parts on the motor..
its a b20 with a vtec head.
Old Apr 11, 2009 | 01:53 PM
wade's Avatar
if the motor is built correctly, go get a hondata, a good turbo kit, no cheap ebay ****, and have a legit shop install it and tune. 250 is easy to get to. but... b20s have very weak sleeves.
Old Apr 11, 2009 | 02:02 PM
thanks for the adviceee.
Old Apr 11, 2009 | 03:03 PM
TheTerdDa's Avatar
with that in mind sleev you b20 block believe me
Old Apr 11, 2009 | 05:02 PM
wegotmorrison's Avatar
LS/VTEC Turbo, Or LS/Turbo or Honda/Turbo, You're not going to have anything as reliable as a stock Integra. I wouldnt turbo a DD, you're just asking for problems.
Old Apr 11, 2009 | 10:19 PM
jdmnic91's Avatar
Default Re: your thoughts on ls/vtec/turbo
i didnt know that a b20 was a ls.. i thought the b18a's and the b18b's were ls motors
Old Apr 11, 2009 | 10:58 PM
hickle's Avatar
its not of course. i think the OP is confusing "LS" as a catch-all word for "non-vtec". but to answer your question, i wouldnt turbo a b20 if i had one.
Old Apr 11, 2009 | 11:18 PM
teggything's Avatar
b18a and bs as well as the b20 have the same crank, stroke, and rod. only difference is the bore of the cylinders so pretty much an ls, but you can easily make the b20 hold boost by sleeving your block
Old Apr 12, 2009 | 12:36 AM
jdmnic91's Avatar
what head do you have on the b20? b16, b18c(gsr), or a rare b17 head?
Old Apr 12, 2009 | 05:37 AM
thats for the information everyone.
the heads a b18c
Old Apr 12, 2009 | 06:41 AM
wade's Avatar
For anyone saying that b18 and b20 are the same sleeves, just bored out... IS WRONG. The b20 is an entirely differently designed sleeve. It is ten fold weaker.
Old Apr 12, 2009 | 06:43 AM
teggything's Avatar
but you can sleeve ur block and it will be fine
Old Apr 12, 2009 | 08:26 AM
Schister66's Avatar
Man U FTW
Go to the Forced Induction forum and research.
DA_Manny
Nov 6, 2007 03:35 PM
JDMJunior
Jul 24, 2006 06:53 AM
xfrankx
Aug 18, 2005 06:21 PM
Glocker
Aug 16, 2005 08:29 PM
t . b o z
Feb 15, 2004 03:33 PM
