FS: 1996 Integra Daily Driver
SOLD
I am selling a 1996 Integra which was my brother's daily driver, with an Integra LS engine, which has about 100k miles on it. The chassis is actually a GS-R with 78k miles on it, due to be a stolen recovery almost 10 years ago, but it currently has a clean title with no legality issues and is reliable to and from work.
Details:
Engine runs very good, smooth idle, no oil burning
No engine codes
reliable
Engine compression test : 195 - 205 psi across
clean spark plugs
new valve cover gasket, spark plug grommets & washers
good condition brakes
Bridgestone Potenza Tires - approximate 7k miles
good condition OEM obd2 Catalytic Converter from 97 Integra
good condition OEM exhaust from 97 Integra
new OEM spring loaded bolts / nuts for cat connection
clean interior
new battery
new cam end plug seal
obd2 LS intake manifold w/ new gasket
obd2 LS P75 ECU
obd1 LS engine harness (although, has evap & ckf wired in)
taken off registration recently
needs new inspection
exterior has some scratches, chips and minor dents
SRS light is on
ABS light randomly comes on
Overall, this is a solid and reliable daily driver Integra, which is a great vehicle as is. I am asking $2500, and am located in central New Jersey, near exit 8, off the NJ turnpike, also near route 9 and route 33.
thanks,
i.
Details:
No engine codes
reliable
clean spark plugs
clean interior
new battery
obd2 LS P75 ECU
SRS light is on
thanks,
i.
It doesn't apply like that. It has an "s" on the title, so insurance was not the rated the same as a GS-R for insurance. It's cheaper. Good thought though.
DrakeMK3
Sep 7, 2006 01:37 PM
