will 91 ls teg axles work...?
i am in the process of 91 ls swapping my crx and the drivers axle is a hair too long for lower ball joint to line up the guy i got the axles from claims they are ls axles will they work on my crx??
You can use the DA axles but those are still too long. Yes they will work, but they are not the correct size. The Drive shaft shop and raxles and make the correct size for you.
