IACV HORROR STORY! Help 95 integra
Old Apr 10, 2009 | 04:25 PM
Integra4lyfe069's Avatar
Default IACV HORROR STORY! Help 95 integra
so i took it off to clean it and take it apart and what not.
Upon taking it apart one of the screws holding the plate in tact snapped, now i have the thread i there and i tried to drill it out and it went of course and now the hole is massivly big and stripped and totaly ****ed up. anyway to fix this or do i need get a whole new one.
Old Apr 10, 2009 | 05:17 PM
teggything's Avatar
Default Re: IACV HORROR STORY! Help 95 integra
get a new intake itll prolly be pretty cheap if its an ls
Old Apr 10, 2009 | 05:43 PM
nonsense's Avatar
http://www.timesert.com/
Old Apr 10, 2009 | 06:34 PM
94EG8's Avatar
Seagull Management
So you just screwed up the IACV? IIRC OBD1 D-series IACVs are the same, and are extremely easy to find used.
Old Apr 10, 2009 | 07:55 PM
teggything's Avatar
if he broke the bolts with the iacv on he should have tried vice grips, i think hes talkin the head cuz u cant really mess up an iacv by making the holes too big unless you went way over
Old Apr 10, 2009 | 09:06 PM
i got the iacv off the engine easily.
i started taking the two 8 mm bolts off the end to get the spring and center pieces out.
The first one came off easy, the 2nd one snapped the head off as i turned it.
so the top came off n i cleaned the entire thing and took it apart n reassembled it.
but i tried drilling out the one screw that was stuck in the hole for the cover but the bit i used went off middle and drilled into the thread and made the hole bigger then it accualy is, so i used a screw remover set to get the rethread bit to rethread the hole but the bolt wont fit im trying to find new bolt to fit but having difficulty ;p
cause of the way the hole is lol im trying to get a clear pic but the gd camera only takes white blurry pics of it if i get to close and nto clear enough far away grr
Old Apr 11, 2009 | 05:52 AM
whitengolddc2's Avatar
just get a new one.
Old Apr 11, 2009 | 11:58 AM
teggything's Avatar
does ur sensor have a electrical plug on it or just 2 hoses if it has hoses its the fitv on the bottom of the throttle body but yes i agree they are cheap used get one fro a junk yard
jdmcivic2fast
Jun 27, 2013 11:45 PM
crazyhouse2011
Mar 24, 2013 11:49 AM
EJ8_Man
Dec 19, 2011 05:26 PM
Mr_B18C1
May 21, 2011 08:52 PM
Ranilla07
Apr 21, 2011 03:25 PM
