Hi need help Honda metal guage thickness??
Old Apr 10, 2009 | 04:04 PM
blue2000em1's Avatar
Default Hi need help Honda metal guage thickness??
Can someone please tell me what guage is the metal in a Engine bay in a Honda?? We had our Mig welder set as 22 guage and it would burn through.Now we are going to cut pieces of sheet metal and stick them underneath the holes and weld through the hole to fill it in???
Old Apr 12, 2009 | 05:52 PM
ManBearPig4silly's Avatar
Default Re: Hi need help Honda metal guage thickness??
then you are welding it to slow or trying to go vertical up or something silly like that.
Old Apr 13, 2009 | 02:56 PM
fizic's Avatar
turn up the wire feed, or weld faster.
Also before you begin make sure you dont have any shielding gas leaks.-could contribute to burn-through.
If your filling holes,a copper backing plate would allow you to fill your holes with just the welding wire as copper wont melt into the puddle.(has a much higher melting temp.)
Hope that helps.
Dave.
that-guy
Welding / Fabrication
17
Jun 20, 2011 06:16 AM
that-guy
12
Mar 23, 2011 09:48 AM
iBrandon
Feb 29, 2008 06:39 PM
jaydmcrx
Oct 18, 2005 06:45 PM
onePOINTsix
Jul 5, 2005 06:15 PM
