fs; b16a2 longblock
im selling my half assembled project.
its an obd2 b16a2 block, with a b16 head.
the block is in perfect shape but, i took the pistons out to use them for an ls/v build that im putting to the side for now. so you'll need new bearings. also has stock flywheel that will need to be resurfaced.
i have everything you need to put the head together, its just not assembled. fresh valves too, with dual springs on the intake side. the head did have a hole in it but, was welded and tested with NO leaks, it was also hot tanked while bare.
i also have the intake manifold, bare minus injectors. b16 valve cover which i stripped so, youd have to paint it.
the only things i dont have is:
-tranny
-distributor
-vtec solenoid
-head studs
-ecu
**pictures of the head will be up asap.**
im not looking to part it out at this time.
like to get 700 OBO for it disassembled.
-tranny
-distributor
-vtec solenoid
-head studs
-ecu
vietjdmboi
Dec 10, 2009 04:52 PM
