1st gen b16 dizzy parts and spark plugs
Old Apr 10, 2009 | 01:32 PM
MIGPA26's Avatar
Default 1st gen b16 dizzy parts and spark plugs
I have a 1st gen b16, i need to get a new dizzy cap and rotor along with spark plugs.
What does everyone suggest?
any help would be greatly appriciated!!!
Old Apr 10, 2009 | 01:50 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: 1st gen b16 dizzy parts and spark plugs
A member named "Monty" compiled this list and it
was accurate for everything I replaced:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orifice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Old Apr 11, 2009 | 07:38 AM
MIGPA26's Avatar
Thanks all that info will help...
plastik462003
Dec 27, 2004 02:28 PM
coot_er
Mar 4, 2004 04:58 PM
luckybull
Dec 26, 2003 03:16 PM
91hatchnewb
Apr 28, 2003 01:54 PM
bluecrxsi
22
Feb 25, 2003 04:47 PM
