Rotor Holding Screw Head Broke HELP!
So How do I get this out, I didn't do it, I noticed when I was painting my calipers today when I went to turn them to finish the bottom after drying, they got stuck a little bit before moving freely but only on one side.
I inspected the holding screws and found that one head is broken off on the side that its fitting a little snugger then the other side and I'm wondering how do I get the rest of the screw out so i can replace with a new one any ideas?
looks as if its doing nothing for the rotor cause i think this is the reason the rotor is a little harder on one side to slide past the brake pad.
Just drill the rest of the head off if you need to get the rotor off. If you don't have to remove it then don't even worry about it. That screw is not causing your rotor to be tighter on one side vs. the other. Remember, you wheel gets torqued down directly to that brake rotor.
yeh the rotor doesnt need replacing i just thought about it when i seen it and figured it was worth posting for when i do goto change it so there wouldnt be any confusion or problem.
thanks
aTrOcIoUs420
Mar 16, 2010 08:02 PM
a1320addict
Jan 17, 2006 10:16 PM
spnbb2
Nov 28, 2004 01:03 PM
