Front wheel stud broke. Need help, please!
Old Apr 10, 2009 | 03:32 AM
dc2luva's Avatar
New User
Icon6 Front wheel stud broke. Need help, please!
I have a 2001 Integra GSR. One of the wheel studs in the front broke. Tried to replace it, but got into some problems after taking out the break caliper and the rotor.
I don't know how to get it out. What do I need to do? Please help.
Old Apr 10, 2009 | 05:37 AM
felixjr18's Avatar
Default Re: Front wheel stud broke. Need help, please!
he easiest way to do it would probley be taking the whole hub assebley and knock them out but most likey you'll need a new wheel bearing... also if you do it that way you'll need to press the wheel bearing back into the hub so also invest in that... or! you go from the back of the stud and shave it into the shape of a D so it will clear the groove on the hub and then you wont need to press the hub back in...
Old Apr 10, 2009 | 05:55 AM
mrdeadman's Avatar
They let me pick
Materials:
2 clamps.
Thick piece of metal.
Position the metal over wheel stud in question. Clamp down over wheel stud, slowly increase clamp tightness. Eventually wheel stud will pop out. You may be able to do the same thing on the other side to put a new one in, I don't remember how much clearance there is...
Old Apr 10, 2009 | 03:45 PM
dc2luva's Avatar
New User
Icon7 Re: Front wheel stud broke. Need help, please!
Thanx a whole lot guys. I will try shaving the the back of the stud, just take it that way. Using clamps is a good idea, never thought of that.
Thanx.
streetracer_305
18
Jun 20, 2015 01:59 PM
EK_EG_DC
Mar 16, 2009 08:54 PM
Pompiuses
Sep 12, 2005 06:57 AM
turbob16ef
Suspension & Brakes
Sep 3, 2005 12:16 PM
