Temp gauge goes up and down..
Hi guys, I have a problem and I'm stumped. When driving my temp gauge goes up and down as if it's overheating. It happens randomly. I thought there was air in the system so I ran it without the radiator cap for a while to let it bleed. For the past couple days I've been letting it warm up and then opening the cap slightly to let the air escape but it seems to never run out of air...
I opened the radiator cap today again this morning. There was some pressure built up from last night and air escaped. I'm letting it idle right now with the cap off.
It's a 97 gsr. Yes, I moved the slider to fully hot. I read that if the bubbles keep coming it might be a blow head gasket...I hope it's not that. I checked the dipstick and oil looks fine. Dirty but not milky...
you can use a coolant pressure tester and if it does not hold pressure there is a coolant leak.
Does the upper hose become hard after just a few minutes being started?
if so then you might have a head gasket issue pressure building in the cooling system.
But if you install the pressure tester on the rad and pressure builds then it is head gasket!
I would drive and the temp would go up. When I let off the throttle for a bit the temp goes down. The heater hose busted today so there might be more air in the system?
Is the head gasket an easy fix? Can I do it myself?
Do you think that the heater hose could have been cracked and leaking before it broke? I would replace the hoses and check again. A head gasket is neither cheap or easy to replace.
It might have had a tiny hole. When I noticed that it busted it had a rip near the clamp about 3/4" on the side where in goes into the block. I'm about to do a coolant pressure test to see if it holds pressure. Thanks for your help guys!
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
