alt. belt...
Old Apr 9, 2009 | 09:44 PM
killafred187's Avatar
Default alt. belt...
i have a civic 1989 with a d-15b1 with everything stock except the alternator and water pump and when i start the engine the gaddamn alt belt squeals for a couple of secs then it goes away WHY!!!????
Old Apr 9, 2009 | 10:07 PM
~sp33~'s Avatar
EFB055
Default Re: alt. belt...
It's stretched? Needs to be adjusted?
Old Apr 9, 2009 | 10:10 PM
wha? wadda u mean "streched"?
Old Apr 9, 2009 | 10:15 PM
boostedefhatch's Avatar
its more than likely got dry rot, its gone bad mine did the the EXACT!!!! same thing replace it its so easy i think i loosened two bolts that's it and cost me less than 10 bucks for the belt at auto zone, my car used to squeal all the time upon start up, its embarrassing but very easy to fix look no further buy a new belt
Old Apr 9, 2009 | 10:26 PM
thanks peps peace
Old Apr 9, 2009 | 10:54 PM
no prob bro
Old Apr 9, 2009 | 11:07 PM
~sp33~'s Avatar
EFB055
It's probably old, so the circumference is slightly larger, meaning it's not tight and it will slip.
Old Apr 10, 2009 | 05:44 AM
honda.lioness's Avatar
Did you replace it recently? Is it the correct belt? If so, the tension is not set correctly. Re-tension using page 7 of http://media.honda.co.uk/car/owner/m...H200/16-58.pdf .
If it is an old belt, check that your tensioning bolts have not loosened. Consider replacing the belt and re-tensioning correctly.
Very common problem for those kinda new to replacing drive belts.
rodz
Mar 2, 2016 07:43 PM
xminnis
Classic Hondas
Jan 26, 2009 06:27 AM
Dj Skidz7
Apr 20, 2008 06:03 AM
2SlowDC
Jun 4, 2006 12:10 PM
mohsinkhan35
Sep 2, 2005 06:21 PM
