FS: many Integra & B series parts, interior and underhood parts, LOW PRICES!
Old Apr 9, 2009 | 07:38 PM
sweet's Avatar
Icon7 FS: many Integra & B series parts, interior and underhood parts, LOW PRICES!
how's it going! i have alot of parts left to sell yet, mostly smaller items but they need to go. prices DO NOT include shipping costs and i accept Paypal. i will not post pics here cause there are too many parts. so just PM with your email address so i can send you pics. and any questions just PM me.
THE FIRST SECTION (BELOW) CONTAINS HONDA OEM PARTS BNIB:
92-95 Civic Hatchback REAR Fender liner/protector (set of 2 for both sides), Honda part # 74430-SR3-A00 = $15/pair
SOLD B18C Main cap bolts (set of 10, 6 for the girdle and 4 for the end caps) = $35
Shifter bushing bolts (x2, part # missing on bag), bolt "sleeves" (x2, part # 54114-SB2-000), bushing "brace" (x1, part # 54307-SB3-010), shifter lower dust seal (x1, part # 54109-SA7-000), lever ball seat (x1, part # 54110-SH3-003) = $20 for the set
Right Front engine mount "stopper bolt", slides through the rubber mount and the washer and nut goes onto it to keep the mount in place on the trans bracket, part # 90133-S04-000 = $8
Transmission housing seal, where the right side axle locks in place, part #
91205-PC9-711 = $5
SOLD B16/B18 cam seal, part # 12513-P30-000 = $4
B16/B18C Main bearing pair, Green color, part #13344-PR3-004 & #13324-PR3-004 = $12 for the pair
SOLD B16/B18C Main bearing pair (1 lower and 1 upper), Brown color, part #
13343-PR3-004 & # 13323-PR3-004 = $12 for the pair
B16/B18C Main bearing pair (1 lower and 1 upper), Blue color, part #
13341-PR3-004 & # 13321-PR3-004 = $12 for the pair
B18C Rod bearings, 1 pair of Green color, part # 13214-P72-003 = $10
B18C Rod bearings, 1 pair of Brown color, part # 13213-P72-003 = $10
B16/B17 Rod bearings, 1 pair of Brown color, part # 13213-P30-004 = $10
SOLD B16/B17 Rod bearings, 1 pair of Green color, part # 13214-P30-004 = $10
SOLD B series injector to IM seals (set of 4), part # 16472-P10-A01 = $25/set
SOLD B16/B18C valvecover washers/seals (set of 8), part # 90442-P30-000 = $16/set
SOLD B series valvecover "chrome nuts" (only 3), part # 90213-PH3-000 = $5 for all 3
B16/B18C cam cap bolt/stud (only 3), part # 90014-PR3-000 = $10 for all 3
ALL PARTS BELOW ARE USED, UNLESS MARKED "NEW"
ADDED 5/24:
MSD SCI ignition unit--used for 5 years, perfect working condition, mounted inside the cabin of the car (NOT under the hood) so it was kept clean and dry. removed for an upgrade to the MSD Digital 6+. $50
95 GSR OEM intake manifold--still assembled with vacuum canister and hose, NO sensors, TB, rail or injectors---> $25
97 Integra Dash parts/switches/electrical/misc (take it all for a low price!!):
Sunroof switch---> $5
Dash Illumination switch---> $5
Cruise control switch---> $5
SOLD Driver Side Vent (black)---> $5
Foot Rest Pedal---> $3
SOLD Ashtray (black)---> $3
Driver Side "coin tray"---> $5
Underdash "control box", silver metal w/2 gray sockets---> $5
Underdash "control box", rust color plastic w/3 gray sockets---> $5
Hazard switch---> $3
Defrost switch---> $3
Dash Vent for behind climate control---> $3
Driver Side kick panel cover (Tan)---> $5
Passenger Side kick panel cover for ECU (Tan)---> $5
ECU metal "protection cover"---> $5
Glovebox (Tan)---> $10
Center Console (Tan), 2 piece set, armrest, shifter boot, etc---> $10
Door Panels (Tan)---> $20 for the pair
Passenger side airbag (Tan)--$30
00 B16A/SI OEM valvetrain set, 16 valves, 24 valvesprings, 16 retainers, 32 keepers, no damage to anything---> $135 (if you need just certain parts PM me)
SOLD B series timing belt tensioner with spring---> $15
SOLD B series timing belt gear (located at oil pump)---> $5
complete steering column from steering rack through the firewall to the steering wheel. Nothing is damaged. All wires, airbag, wheel are there. TAN color wheel. It's from a 97 Integra LS with power accessories---> $100 OBO
B18B Auto Tranny, nothing missing, complete w/starter etc---> $50
SOLD 97 LS Fuel Rail/Injectors/Fuel Line (from filter to rail)/FPR set, no damage, all OEM parts---> $45
NEW thermal IM gasket for GSR IM, NOT Hondata---> $35
NEW thermal TB gasket for B/H series, 70mm size---> $15
B series timing side engine mount with 1 stud (OBD0 i believe, x2)---> $8 each
NEW Gorilla chrome lug nuts, new condition, 12mmx1.25 size (not sure if it fits Civic or Integra studs since i never tried them), 14 are Gorilla and 2 are not but look nearly identical. i'm not sure how i ended up with 2 oddballs. LOL i got these awhile back with a set of wheels and never used them. included is the socket attachment to torque them down---> $10 for the set
SOLD 97 Integra Alternator, OBD2, OEM unit, spins freely and worked when pulled-- $20
97 LS underhood fusebox, next to battery, includes all inside fuses and cover--> $8
97 Integra OEM battery cables, from fuse box to battery, and from battery to starter----> $6
97 Integra cruise control box, underhood unit, includes uncut throttle cable---> $15
Integra coolant passage control piece/valve for firewall, allows coolant to flow through the firewall to the heater core inside under the dash, no damage, includes hose---> $10
94+ Integra OEM intake, from TB to airbox, includes used OEM filter---> $10
92-95 Civic OEM front shock fork set--$10
92-95 Civic hatch rear fender edge liners, OEM, new in package--$10
92-95 Civic DX working gauge cluster, 102,790 miles--$10
OEM B series injectors, 240cc (OBD2)--$25 for the set
Integra OEM subframe reinforcement bar, near steering rack--$20
97 Integra "wheel well liners" , no damage--$25 for the pair
97 Integra OEM rear wing, dark green color, no damage, with uncut wires--$30
SOLD 97 LS OEM IM with sensors--$20
97 Integra ABS unit, underhood distribution unit--$15
97 Integra battery tray with OEM plastic battery cover--$8
OEM Resistor box--$10
00 GSR OEM headbolts, all 10, torqued 1 time--$10
OEM 99 GSR valvespring set (all 24), from 100% stock motor-- $25
OEM 99 GSR valvespring retainer set-- $25
GSR fuel line, from filter to rail, with protection sleeve--$15
SOLD B series AC/engine mount (one compressor bolt hole has broken off bolt)--$10
B series rear block coolant passage, from pump to thermo housing (x2)--$5
B18 IM bracket (x3)-$7
B18B1 OBD2 Auto ECU--$20
SOLD B16 IACV--$8
92-95 Civic RLCA's, no sway bar mounting, bushings good--$20 for the pair
94-01 Integra RLCA's, sway bar mounting, 1 bushing needs replacing--$20 for the pair
Old Apr 9, 2009 | 08:01 PM
greentegls's Avatar
New User
Default Re: FS: many Integra & B series parts, interior and underhood parts, LOW PRICES!
can I take a look at those 97 tan door panels and possibly pick them up tomorrow if in good condition? The spoiler also.
Old Apr 10, 2009 | 06:51 AM
sweet's Avatar
sure thing! here are the only pics i have on hand. the wing is really dirty, but not damaged. the paint is actually really good condition, just not seen in the pic. but i can get you more pics.
Old Apr 10, 2009 | 08:14 AM
greentegls's Avatar
New User
that spoiler looks fresher then mine, where are you located i have off school and work all day
Old Apr 10, 2009 | 09:53 AM
sweet's Avatar
PM sent!
Old Apr 10, 2009 | 11:45 AM
sweet's Avatar
Bump it up!
Old Apr 10, 2009 | 08:51 PM
Eli2's Avatar
Interested in the T-bracket, Is it from an auto or manual?
LMK
Thanks
Eli
Old Apr 11, 2009 | 10:55 PM
sweet's Avatar
LMK
Thanks
Eli
PM sent!
Old Apr 12, 2009 | 10:24 AM
sweet's Avatar
Bump!
Old Apr 12, 2009 | 02:21 PM
Eli2's Avatar
Replied! Bump!
Eli
Old Apr 12, 2009 | 06:46 PM
sweet's Avatar
Replied! Bump!
Eli
yes sir, PM's sent! here is a pic for those who are interested in the T brackets. tomorrow night i will get more pics of them.
Old Apr 12, 2009 | 07:30 PM
Eli2's Avatar
I sent you an email. I need one from a 90-93 teg. Sorry for the trouble man.
Thanks
Eli
Old Apr 12, 2009 | 07:51 PM
sweet's Avatar
bump for new parts added!
Old Apr 13, 2009 | 09:29 AM
sweet's Avatar
Afternoon bumpity!
Old Apr 13, 2009 | 12:11 PM
Eli2's Avatar
Bump!
Eli
Old Apr 14, 2009 | 03:39 AM
sweet's Avatar
thank you sir!
Old Apr 14, 2009 | 07:17 PM
sweet's Avatar
night bump!
Old Apr 15, 2009 | 12:52 PM
sweet's Avatar
bump
Old Apr 15, 2009 | 02:49 PM
sweet's Avatar
Icon6 Re: FS: many Integra & B series parts, interior and underhood parts, LOW PRICES!
here's a pic of the 2 IACV's i had for sale. the one on the top is the one still for sale. i'll get a pic of the connector and back soon and post it up.
Old Apr 15, 2009 | 07:47 PM
sweet's Avatar
bump it up!
Old Apr 16, 2009 | 07:52 AM
sweet's Avatar
pics of injectors seals, studs and caps for valvecover
Old Apr 16, 2009 | 01:58 PM
sweet's Avatar
bump!
Old Apr 16, 2009 | 06:13 PM
sweet's Avatar
night bump!
Old Apr 17, 2009 | 02:56 AM
sweet's Avatar
Icon3 Re: FS: many Integra & B series parts, interior and underhood parts, LOW PRICES!
here are pics of some items for interested members: the last pic is the B16 IM w/o sensors
Old Apr 17, 2009 | 02:28 PM
sweet's Avatar
going up
