code 20 help
Old Apr 9, 2009 | 07:37 PM
dracocrx's Avatar
Default code 20 help
I keep getting a code 20 I know what it means I just need help on how to fix it my friend had the same code he changed his alternator I did that and I still get the code and a cel I searched an found that some people had to change the main fuse box tried it still not going away checked all my grounds im am just out of ideas where do I go from here any help would be helpful thank you for your time
Old Apr 9, 2009 | 07:47 PM
classdork987654's Avatar
Default Re: code 20 help
try disconnecting your deck and then re connecting it. also reset ecu. this helped mine, i had shity connections with loose wires. same thing happened when i put my alarm in, had wire pull out of connecter. i would check all wires/wiring of stuff you have or had someone install in the car.
Old Apr 10, 2009 | 05:47 AM
honda.lioness's Avatar
Code 20 is for the Electric Load Detector. Pretty common problem. See http://search.yahoo.com/search;_ylt=...myy&fr2=sb-top
usdm_ED7
Aug 30, 2011 09:30 AM
0ne-Cam
14
Aug 20, 2009 06:58 PM
earkicker
Honda Civic (2006 - 2015)
13
May 14, 2007 08:57 PM
MilanoFury
Jul 30, 2005 07:30 AM
