D16 Turbo Setup
Old Apr 9, 2009 | 07:33 PM
AllTracCelica's Avatar
Post D16 Turbo Setup
Hey guys,
Don't batter on my and stuff for asking this. Looking to turbo my D16 I can buy turbo kit for like 3200$ with everything i need. But can anyone give me links to each parts i need to build a setup cheaper? Not egay cheap parts. Stuff that is dependable. Complete setup what i should go with.. Thanks in advance.
Thanks,
Dereck
Old Apr 9, 2009 | 07:58 PM
xnvb's Avatar
Default Re: D16 Turbo Setup
http://www.go-autoworks-store.com/gocotuki.html
Old Apr 9, 2009 | 08:00 PM
SOHC_civic_si's Avatar
If you are asking that question then you have a lot to learn and I hope you do not plan on doing the work yourself
Old Apr 9, 2009 | 08:16 PM
95sloweg's Avatar
heres a link that will answer majority of your questions. if you have no idea what parts are needed then you have a long ways to go before you just drop in a turbo and call it a day. https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Old Apr 9, 2009 | 10:45 PM
jeffsciv23's Avatar
read this http://www.realhomemadeturbo.com/for...hp?topic=682.0
guy ran a 10.54 and probly has less then half of that in his entire build including the car lol. ive never spent more then 900 on piecing together a turbo kit and the only reason it costed that much is because i wanted a few baller parts that i didnt need. just read and do your research so that you dont get screwed and you will learn at the same time.
good luck
Old Apr 10, 2009 | 02:03 AM
sohcrex808's Avatar
New User
i agree wit above go autoworks will have everything u need and they sell complete kits
Old Apr 14, 2009 | 01:20 PM
Sweet thanks guys. I know basics of a turbo only thing i have turbo is My Celica. It came turbo only thing i have done is a turbo upgrade. Have not turbo'ed a civic that have to adjust everything to cope with the turbo Used to the car accepting. Thank you guys for all the advice.
Thanks Dereck.
Old Apr 16, 2009 | 07:58 PM
Hey guys,
Thanks for all the help. Looking at doing the Autoworks Tuner Kit. Sounds like pretty good to me. What else am i going to need with this setup? That is not included in the kit? What ecu to run where to get ecu tuned from? Also looking at set of Vitara Pistons. And Eagle connecting rods. Can get brand new Vitara 75mm Bore with rings for 120$ shipped fair deal? What is required on putting in new rods and pistons? These are 8:5:1 Compression as well. And where to find the eagle connecting rods?
Thanks Guys.
Old Apr 17, 2009 | 08:06 AM
Progressing a little farther ahead right now this is what I am looking at as far as setup. And goals to hit 350-400hp.
- GO-AUTOWORKS Stainless Log Manifold
- GO-AUTOWORKS SS 2.5" downpipe
- GO-AUTOWORKS dumptube
- Bullseye Power T3/T4 57 trim .55 A/R
- Tial 38mm silver wastegate
- Tial 50mm silver blow off valve
- complete oiling kit
- GO-AUTOWORKS Race charge pipe kit
- GO-AUTOWORKS bar & plate intercooler
- (6) high quality silicone reinforced couplers
- (12) stainless T bolt clamps
** Now offered with the Bullseye Power Turbochargers!!**
Fits:
92-00 Civic: D or B series
Price $2395.99
Wiseco Pistons Eagle Rods 75mm(STD) 8.5:1 $739.99
ACL Race Bearing Kit $125
Cometic Headgasket $100
ARP Head Studs $110
Supertech BlockGuard $95
Hondata S300 $585.99
Supertech Valves $269
Supertech Springs and Retainers $299
AEM Cam Gear $115
Crower Cam $375
Grand Total $5209.97
Are these prices pretty good or can anyone let me know where to find cheaper? Also looking to do cam gear and cams but don't know what to look for in the way of duration and what not.
Thanks,
Dereck
Old Apr 17, 2009 | 09:36 PM
Post Re: D16 Turbo Setup
Bump anyone?
generalfred
Sep 8, 2010 07:22 AM
Goosse
Dec 9, 2003 11:21 AM
dingusjt
Oct 10, 2002 08:32 PM
