Honda S2000 Honda S2000
New wheels, but afraid to mount
Old Apr 9, 2009 | 03:20 PM
shamoo's Avatar
Will you make something up for me please?
Default New wheels, but afraid to mount
EDIT: Mounted...sorta. Updates in last post
So after going back and forth for quite a while in my head, I finally decided to get some wheels since I needed to buy new summer tires anyway. Why not get some wheels while I was at it?
These are Carving Stark IIIs by Work. Got them brand new from a member on s2ki. I heard they were last made in 1994 or something. Anyway, they arrived today.
Front: 17x8 +43
Rear:17x9 +47
Going to try to put existing Falken Azenis RT615 215/45s on the front and purchase new 245/40s for the rear. This is the first time in my life attempting something that's somewhat aggressive. What are your thoughts? Will I have to do any crazy fender work? I was told maybe and run some negative camber. I'm already at -2.5 with OEM AP2v2 lowered on Espelir ASDs. Not sure what else I will have to do with these.
Here are some pics I took a few moments ago.
Packaged really nicely.
This is the rear wheel.
Test fitting.
So what do you think? Doable?
View from the top.
I'm still scared. I'm entertaining a trade for some Advan Racing Version 2 wheels that don't require any modifications. But with shipping and whatnot (to/from Hawaii), it might be worth the effort/time/money.
Old Apr 9, 2009 | 03:33 PM
papa5murf's Avatar
Default Re: New wheels, but afraid to mount
Trade them for the Advan's. But I purely say that cause I like the style of the Advan's more.
Old Apr 9, 2009 | 07:02 PM
shamoo's Avatar
Those Advans were my favorite wheels for years, and I think they still are. It's just that the person is located in Hawaii and it's ~$350 to ship there. I posted this same thing on s2ki and people are giving me mixed answers.
I either have to roll/run negative camber, or I have to get aftermarket fender flares (ASM, Js, etc). I'm fine with the first option since I'm already at a pretty aggressive camber, but I'm definitely not keen on the aftermarket fender flares.
I'm looking back and forth at the Advan pictures, and I think I'm gonna do the trade. Sigh...
Old Apr 10, 2009 | 05:21 AM
White Smoke's Avatar
i my honda
Global Mod
You should not have to add any camber to run these but you will have to roll your fenders and re-locate the tab. It's easy to do, but if you are unsure about it take it to someone who has done this before. The last thing you want is a creased fender.
Old Apr 10, 2009 | 06:11 AM
matwilliams's Avatar
i think they will look sweet, with a suitable drop and stretch tyres! (probably won't be very safe to drive mind!)
do you guys have the same law as we do in the uk about wheel/tyre widths, ie. wheels are not allowed to stick out past the bodywork?
maybe get the wheels machined to reduce the offset?
mat.
Old Apr 10, 2009 | 06:48 AM
bky's Avatar
bky
Rolling the fender, relocate the tab, and cutting the bumper are a minimum. Not hard to do or get done, so don't be afraid of that. It's really not a big deal.
Azenis run wide, and I think a 245 will be a problem. I think you will need more camber to fit it, or a 235 or 225 tire. If the 245 doesn't fit, try the 215 tire from the front. It will at least tell you if it's possible before messing with the camber.
The fronts should be fine with a roll.
BTW, those wheels are bad-***. Very unique. Keep them!
Old Apr 10, 2009 | 11:49 AM
S2KMoe's Avatar
Rolling your fenders is about all youll have to do,i wouldnt be sweatin it,im runnin same setup with different wheels but with a +22 in front and +27 in rears,and i had to roll,cut,and relocate to make work,but with your higher offsets,youll be fine.
Old Apr 10, 2009 | 12:28 PM
Chris.'s Avatar
Honda-Tech Order of Merit
roll your fenders
2.5 degrees up front with the 215/45
3.5 degrees in the rear with the 245/40 and youll be good
Old Apr 10, 2009 | 12:54 PM
DC2B18cya's Avatar
I'd rock them
Old Apr 10, 2009 | 07:10 PM
marty's Avatar
I replied to your thread in the metro section as well shamoo. Its not that bad, I actually love the Carving Starks. You would probably need to just roll your fenders and call it a day. The -2.5 your running should be fine.
Im going to be running an 18x10 rear with a 45 offset. Stock body but with some work needed. kekeke.
marty
Old Apr 12, 2009 | 06:44 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Originally Posted by Chris.
roll your fenders
Thank you someone who knows WTF they are talking about.....
WTH did all these misinformed people giving advice come from?
Old Apr 12, 2009 | 09:27 AM
Vp Special K's Avatar
Yeah..i was running an 18x9 +45 in the rear, slammed and running 3+ camber. a nice fender roll and relocating the bumper tab should be all that you need to do.
Old Apr 12, 2009 | 09:45 AM
Black S2K's Avatar
dont be a ***** mount some tires roll pull and strech your fenders run -561515617841camber ull be good to go
Old Apr 12, 2009 | 06:44 PM
crazyz250's Avatar
ballller put them on
Old Apr 12, 2009 | 06:54 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
...Afraid to mount?
Crush the rear fender lip, crush the front fender tabs and roll the lip a little bit. Cut a small slit on the fender liner where the tire will be (optional).
Add negative camber till they fit the way you want. It's not hard.
You probably don't even need to relocate the rear bumper tab with 245s and espelir springs.
I didn't relocate mine until I got 255s..and my car is considerably lower than espelirs sit.
Old Apr 12, 2009 | 07:25 PM
MADEinJAPAN's Avatar
go for it!!!
Old Apr 12, 2009 | 08:06 PM
Dann6968's Avatar
Don't forget pictures when your done.
Old Apr 13, 2009 | 09:32 PM
dubster99's Avatar
I'm running 8.5" +42's in the back...I rubbed with 245s and 235s on -2.9deg camber. I'm going to roll fenders and relocate the bumper tab, and probably trim the bumper.
Anybody got any links for relocating the bumper tab? I haven't gone under there to see where it can go yet...just want an idea of what it's like.
Old Apr 13, 2009 | 10:23 PM
B serious's Avatar
It's very obvious. I have pics...but just seeing it will make it more clear. You remove it, grind the metal down or cut it. Then you drill the hole for the bolt towards the back and repaint everything very carefully so there's no rust. It's easy as hell.
You're probably just rubbing on the fender lip. I had 17x9 +45s with 245/40/17s and -3deg of camber (around 1.5 finger gap from tire to fender). I rolled the fender and there was NO rubbing. I didn't have to relocate the tab till I got KWs and went a little lower with a 255/40/17.
Old Apr 13, 2009 | 11:20 PM
dubster99's Avatar
I'm under a finger gap...but I may raise it up.
Old Apr 17, 2009 | 02:09 PM
shamoo's Avatar
Used my dad's car and mine to get all the pieces back to my house. Beautiful day today.
Fronts. Definitely need a roll in the front.
Rears. They fit, but I need to bend the little fender spot back in some areas.
Whole car shot with the test fit. Also need new lugs as the acorn style OEMs won't work with these.
My mom must love me. This is the garage at the moment. I will do some cleaning this weekend.
Old Apr 17, 2009 | 06:04 PM
CR-V's Avatar
i dont they look very good at all..
Old Apr 18, 2009 | 10:51 PM
bigmacnfries's Avatar
They looked better in the back of that other car.
Old Apr 19, 2009 | 05:31 AM
Aarron_M's Avatar
I can't even see em.
Old Apr 19, 2009 | 01:14 PM
shamoo's Avatar
Sorry, my Photobucket account got too much bandwidth. Not sure if I want to shell out some bucks for another 3 months. We'll see. Sorry about that.
