an fuel line with stock rail
Old Apr 9, 2009 | 02:50 PM
Kr4nG's Avatar
Default an fuel line with stock rail
is there a way i can connect a AN fitted hose to a stock gsr fuel rail? i need to connect my line to the stock fuel rail but its leaking fuel from the banjo fitting i got. is there another way i can screw my new line into my fuel rail? or do i have to use banjo fittings.
Old Apr 9, 2009 | 02:55 PM
mike93eh2's Avatar
Default Re: an fuel line with stock rail
yea get this, its what i have..
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 9, 2009 | 03:11 PM
Kr4nG's Avatar
yea i have the hose except my banjo fittings seem thinner than the stock line. is there a way i can just buy the banjo fittings?
Old Apr 9, 2009 | 06:21 PM
mike93eh2's Avatar
you have that EXACT russell hose pictured above? if so then nothing is wrong with it or the fittings, i know first hand. what exactly is the problem?
you can get fittings on summit
Old Apr 9, 2009 | 07:21 PM
srmofo's Avatar
did you put the washer/gaskets back on? they tend to stick to the banjo fittings. there is 2.... one on each side
Old Apr 10, 2009 | 03:30 AM
Kr4nG's Avatar
no i got the hose and fittings from b and r fittings here on H T. it doesnt leak from the filter it just leaks by the rail where i put the big nut on. i was thinking on just getting a new banjo fitting and screwing it in.
Old Apr 10, 2009 | 07:13 AM
mike93eh2's Avatar
whats causing the leak? get new washers and tighten it tighter
Old Apr 10, 2009 | 12:48 PM
Kr4nG's Avatar
its leaking between the washers and the banjo fitting. it was as tight as it would go. wen i compared the differences the oem banjo is thicker and wider. so i was thinking if your hose from summit work on a stock fuel rail then y not just get a banjo from them.
thatdumbass
Sep 28, 2014 07:37 PM
Charlie Moua
Mar 22, 2013 05:17 PM
Jmunk
Feb 23, 2005 01:04 PM
VspecSiR
Nov 25, 2004 01:48 PM
h22acivichybrid
Jun 14, 2004 03:20 PM
