ls flywheel specs
Old Apr 9, 2009 | 02:16 PM
teggything's Avatar
Default ls flywheel specs
does anyone know the minimum turn down specs on a b series flywheel? i took mine to get resurfaced which costs 25 dollars, but when i went to pick it up they didnt make me pay(oreilys) it looks good they didnt mess the surface up at all but i called and asked if they knew the minimum and they didnt and neither does any parts store here in town. any help is appreciated.they might not have messed it up but i would like to make sure
Old Apr 9, 2009 | 10:40 PM
teggything's Avatar
Default Re: ls flywheel specs
ttt pleasehelp i am getting ready to do a 5spd conv. and need to know if i need a new flywheel or if this one is ok
Old Apr 10, 2009 | 07:08 AM
teggything's Avatar
ttt cant find this anywhere help please
Old Apr 10, 2009 | 10:05 AM
teggything's Avatar
there is a pic of the flywheel
Old Apr 10, 2009 | 10:17 AM
b18cKoupe's Avatar
from the helms this is the only spec I could find on the flywheel METRIC/STANDARD
Cluth service runout standard(NEW)0.05(0.002)max
service limit: 0.15(0.006)
I"ll look in the transmission section real quick also.
Old Apr 10, 2009 | 10:28 AM
teggything's Avatar
from the back of my flywheel to the farthest part out it 1.0295
Old Apr 10, 2009 | 10:52 AM
b18cKoupe's Avatar
gimme your email and i can send you the page from the helms, can't post it here.
Old Apr 10, 2009 | 11:10 AM
teggything's Avatar
pmd
Old Apr 10, 2009 | 11:21 AM
b18cKoupe's Avatar
pmd
sent
Old Apr 10, 2009 | 11:56 AM
teggything's Avatar
thanks i dont know if that is what im looking for but i will grab a dial and see what it is
Old Apr 11, 2009 | 11:24 PM
teggything's Avatar
so all i need to check on it is for warpage? they cant have turned it too much?
Old Apr 12, 2009 | 11:31 AM
slaminsam's Avatar
Unless that flywheel has been turned down 5 times before I wouldnt worry about it and just run it. The pic looks like they did a good job. Just make sure to brake clean it before you bolt the clutch up and enjoy your 5 speed.
Old Apr 12, 2009 | 01:53 PM
teggything's Avatar
i have no idea id its ever been turned i got it with all my 5spd **** when i bought it all and it needed turned. i guess ill just try it
THEUSED
Transmission & Drivetrain
Jul 29, 2009 08:23 PM
loco4sho2004
Aug 5, 2008 01:27 PM
See Are X
Feb 20, 2008 08:14 PM
Kataku2K3
Oct 11, 2002 09:49 AM
