what wiring harnes do you use for a type r motor in a crx si.
Old Aug 14, 2002 | 09:09 PM
b16powwer's Avatar
Default what wiring harnes do you use for a type r motor in a crx si.
i might be planing on putting a type r motor in my 91 crx si. what parts do i need, i have hasport motor mounts, shift linkage, what kind of axcels would i need, and the inter shaft, what other parts, and which wiring harnese. thanks
Old Aug 14, 2002 | 10:58 PM
Ivan's Avatar
senior gold member
Default Re: what wiring harnes do you use for a type r motor in a crx si. (b16powwer)
Is that the b16 crx? If it is you have to use a cable tranny so you can keep yours. That means you use your axles and even the same wiring harness. If you can I would do an obd1 conversion and run a chipped ecu. Blown90hatch sell the conversion harness.
Lil_Rex
Oct 12, 2007 11:37 AM
joethejoeman
Nov 2, 2006 02:15 PM
evil civic
Feb 22, 2005 01:24 PM
ransack
30
May 10, 2004 06:39 PM
JDM JOE
Aug 14, 2003 05:03 AM
