How to remove injector
Old Apr 9, 2009 | 07:22 AM
BoltonGSR's Avatar
Default How to remove injector
Yes I know its an easy thing but I dont have time right now to tinker with the stupid search...
What I really want to do is swap injectors from one cylinder to another to see if the misfire I am having changes cylinders.
Dont I have to relieve fuel pressure?
Do I just loosen that bolt on the fpr? Anything else involved?
Old Apr 9, 2009 | 08:24 AM
HondaTom87's Avatar
Default Re: How to remove injector
just take the gas cap off to relieve the pressure...
its as simple as that
Old Apr 9, 2009 | 10:12 AM
arielb1's Avatar
I would disconnect the battery as well...just my opinion. My wife started my car once while the injectors were off for cleaning.
Old Apr 9, 2009 | 10:15 AM
HondaTom87's Avatar
yeah thats a good idea too but I thought that was a given for all engine work lol
Old Apr 9, 2009 | 10:19 AM
sp00ledbseries's Avatar
You have to unbolt the fuel rail im not sure if there are two or three bolts. BE CAREFUL when pulling the injectors out. The o-rings are very delicate if they are old. Also there is little filters inside the injectors make sure those are in right when you put them back in.
Old Jan 28, 2015 | 06:05 PM
nyckid's Avatar
pics
Old Jan 28, 2015 | 06:24 PM
B_Swapped93's Avatar
stop bumping old threads FFS...if you have trouble removing an injector get someone else to work on your car.
Old Jan 30, 2015 | 07:34 AM
silvertaxasteg's Avatar
I am SO fancy!
Originally Posted by nyckid
pics
This is all you get, since you asked so nicely.
Go to the parts store and get o-ring kits for each one. You'll trash 'em being that old.
Book says to crack the fuel filter bolts to relieve the pressure. I remove the fuel pump fuse and crank the engine a few times. No big deal.
Old Feb 13, 2015 | 02:47 PM
nyckid's Avatar
you dont have to reply!! you dont own the site!
Old Feb 13, 2015 | 02:48 PM
nyckid's Avatar
thanks for the help
Old Feb 13, 2015 | 03:51 PM
I beg to differ I run this section pretty well.
Old Feb 13, 2015 | 03:54 PM
standy xsi's Avatar
yup, you are a usual face in this section
all-mtr-teg
Apr 14, 2007 07:34 AM
e jay one
Mar 26, 2007 03:58 PM
B16Jacques
Jun 15, 2005 08:25 PM
turboxsi
Apr 17, 2005 04:15 PM
Mike1486
Mar 27, 2005 01:12 PM
