1994 teg can't mrev over 1800 rpm
Old Apr 9, 2009 | 03:29 AM
ihatesilver's Avatar
Default 1994 teg can't mrev over 1800 rpm
-no check engine light
-timing is ok
-will rev freely in neutral
-can drive about a city block before it starts being unable to get over 1800-2200 rpm. but then does not go away. restarting the car erases the problem for 2 more minutes.
-swapped in a good coil/ignitor, brand new cap rotor (easter is stopping me from getting plugs/wires)
-cooling system is bled perfectly
what could it be? give me things to troubleshoot.
**updated**
-swapped igniter, coil, cap, rotor, plugs, wires. no change.
-swapped thermoswitch, and thermostat which was bad and re-bled the system. no change.
the car runs fine for about 1/2 a block or a block or more even. then suddenly i can't rev over 1800 to 2000 rpm.
i thought it was starving for fuel so i let it return to idle to try to buld some more pressure but that did nothing.
then i realized that if i shut the car off, then restart it immediately, it will be fine again for a while. meaning, if it starts acting up, turning the key off then on again allows it to drive for another 30 seconds or minute. (keep in mind the car will idle fine indefinitely). i don't even have to come to a complete stop, that's how fast we are talking between 'fine' and 'not fine'
today i'm going to test and clean the tps, the iacv, swap injectors etc. tomorrow i'm going to replace plugs, wires and main relay. suggestions are welcome.
**update:
tested every sensor i could today, all were within spec
tps - 5v from ecm. signal voltage ranges smoothly from .5 to 4.5v as you open the throttle.
map - 5v from ecm. vacuum needed to test it further, not sure how to do this
iat - 5v from ecm. @roughly 40f 4.5 ohm @ roughly 70f 2ohm
ect - 5v from ecm @roughly 40f 4.5 ohm
iacv - 12v from ecm, clicks with voltage applied, cleaned and unplugging it causes car to nearly stall out.
disty
ckp 350 ohm
tdc 350 ohm
cyp 350 ohm
cleaned all 3 grounds 1-valve cover 2-tranny 3-next to thermostat housing
there should be no more grounds than this right?
tomorrow when stores open again i'll buy and install a main relay.
*update*
absolutely no difference.
guys this car is ruining my life. I have so many other things to do including running a business that i just don't have the time to be screwing with it anymore. H-E-L-P
Old Apr 9, 2009 | 05:18 AM
foxfai's Avatar
Default Re: 1994 teg can't mrev over 1800 rpm
Had the exact same problem for a month. It was the main relay under the dash. It comes and goes also, it was hard to diagonise.
Old Apr 9, 2009 | 06:22 AM
teknohatchie91's Avatar
main relay or it could be your ignition coil going bad
Old Apr 9, 2009 | 05:47 PM
thanks guys. relay is not something i've tried yet.
mind you the motor and ecm are installed in a 2000 civic. i assume it's the same thing though.
Old Apr 9, 2009 | 06:42 PM
shietzitzkien's Avatar
same thing happened to my friend. turned out to be the coil.
Old Apr 10, 2009 | 07:38 PM
swapped coil and ignitor off y8 disty. it still did it, but then stopped and was fine around the block a few times.. intermittent problem FTL.
Old Apr 10, 2009 | 09:08 PM
CeReal's Avatar
are dizzy and coils the same thing? anywho, dizzys sometimes take up to a month to finally go out.
Old Apr 11, 2009 | 06:47 AM
Oreo-TeCk's Avatar
coil is an internal piece of a dizzy
Old Apr 12, 2009 | 08:15 AM
-swapped igniter, coil, cap, rotor (cant get plugs or wires due to easter). no change.
Old Apr 12, 2009 | 09:47 AM
sp00ledbseries's Avatar
Try swapping out th main relay
Old Apr 12, 2009 | 07:04 PM
paton5g's Avatar
I'm not sure how the main relay would prevent it from revving over 1800. Can someone elaborate on this to satisfy my own curiosity?
Old Apr 14, 2009 | 04:31 PM
i don't know. i assume it would prevent the fuel pump from getting enough current to adequetly supply the motor?
in any case, it wasn't my problem,
BUMP for a car that is ruining my life.
Old Apr 21, 2009 | 12:01 PM
foxfai's Avatar
One of the not so good thing is that Honda have all their cars run on only ONE relay, which is this main relay that we are talking about. There are times when an old relay had is old and the capacitors leak and won't hold charge. This gives you problems like you have.
Fortunatly I found out by going back to the dealer. They check for 30 min without other causes and they think it's the main relay. I got charged under $200 for the diagonistic and the replacement of the unit. Ever since I replaced it, I have no more problem at all.
Also to note that this is an intermit problem. I have drove it more then 2 weeks with rev problem twice on highway (it was bad). Finally gave up and brought it to dealer and changed the part.
91-integra
Jan 28, 2020 10:36 AM
stizz58
Apr 6, 2017 09:25 PM
RACEPAK
Engine Management and Tuning
10
May 8, 2009 05:25 PM
warrenbaity
Apr 16, 2004 11:43 AM
MintFlavored
Nov 11, 2002 12:28 PM
