How much higher will my car sit with 18's?
Old Aug 14, 2002 | 08:29 PM
Beast53568's Avatar
Default How much higher will my car sit with 18's?
When I get 18's for my car how high will it be? 2 inches? Because I need to make my car higher becasue the kit on it is too low to the ground.
Old Aug 14, 2002 | 08:41 PM
str8rcn's Avatar
Default Re: How much higher will my car sit with 18's? (Beast53568)
18's with a eibach pro kit sits perfect.I now have 19's and it looks like a 4wd without the body kit installed.a 215-35-18 will sit stock where my 215-35-19 makes the car sit higher.
[Modified by str8rcn, 9:44 PM 8/14/2002]
[Modified by str8rcn, 9:51 PM 8/14/2002]
Old Aug 14, 2002 | 08:44 PM
satan_srv's Avatar
Default Re: How much higher will my car sit with 18's? (str8rcn)
If you chose your wheel/tire size properly there should be absolutely no change in where your car sits.
The point of matching them ensures you have the same overall rolling diameter. http://www.miata.net/garage/tirecalc.html
Old Aug 14, 2002 | 08:45 PM
Mike95lude's Avatar
Default Re: How much higher will my car sit with 18's? (satan_srv)
yep.
Old Aug 14, 2002 | 09:44 PM
Beast53568's Avatar
Default Re: How much higher will my car sit with 18's? (Mike95lude)
The thing is I want my car to sit higher. My car is so low with this kit I have on so I wanna stay away from scraping the concrete. Any suggestions?
Old Aug 14, 2002 | 10:32 PM
typeSwarrior's Avatar
what kit is it? It can't sit any lower than my Buddy Club or the Black Widow kits. I'm rolling on stock 16s until friday (17s in the mail im happy) and ground clearance is NO problem--we have the worst streets too. With 18s you should be fine, seriously.
Old Aug 15, 2002 | 12:55 AM
2.2dc2's Avatar
Default Re: How much higher will my car sit with 18's? (typeSwarrior)
the real question is: how much slower will i go with 18s as compared to 16s-17s
Old Aug 15, 2002 | 01:07 AM
Buckwild's Avatar
If you want your car to sit higher, then raise it the right way with springs (coilovers). Getting tires that are WAY out of spec will cause your speedo to be way off.
Old Aug 15, 2002 | 06:32 AM
satan_srv's Avatar
Default Re: How much higher will my car sit with 18's? (Buckwild)
Although I don't see it being too bad of a thing with 18's. The tire you will have to use for 18's is 215/35 series, that's a thin-*** tire!! If you want to regain some measure of ride quailty, getting slightly higher profile tires isn't a bad idea.
But...according to the calcualtor even if you got 215/45/18 tires your overall tire diameter would only increase 1.5 inches, so that's only 3/4 of an inch up off the ground...and you speed is off 6.4%...
Do it right with springs like buddy says, you gotta pay to play
HondaGSX
Mar 3, 2013 08:06 PM
JuneBugDrfter
Jul 18, 2010 12:16 PM
EJ8 GSR-T
Honda S2000
Aug 6, 2007 10:59 AM
Floored
Mar 25, 2005 10:30 AM
EGB18C
Jul 22, 2004 12:32 AM
