b16a camnsahft degreeing
Old Apr 8, 2009 | 03:39 PM
Paul26's Avatar
Default b16a camnsahft degreeing
im trying to install adjustable cam gears on my b16a and im going to degree them. can some one tell me what degree I should be at on my degree wheel when the intake lobe is at .050 on both the closing and opening ramps. as well as the same thing for the exhaust lobe. I hope ur able to understand what im asking for, basically info that would be on the cam card for stock b16a cam shafts..
Old Apr 8, 2009 | 04:20 PM
Rocket's Avatar
Default Re: b16a camnsahft degreeing
If you are degreeing, then you can benefit from optimizing the lobe centers (away from stock settings).
Stock should be 101/109 in/ex lobe centers.
You can do 99/105 for a 'hotter' setup.
[Don, let me know if you have better numbers than what I recommended here.]
92tegb16
Apr 30, 2007 11:19 AM
ej2civic
Dec 1, 2006 12:36 AM
01-0041
Jun 14, 2005 12:19 PM
wagon-r
May 8, 2004 12:22 PM
88whitehf
Mar 28, 2003 11:29 AM
