help bad compression
ok i have a 90 dx w a b16a 0bd0....was running great i put a vafc2 in it and started it and it would bog a bit when i hit the gas turned it off and back on and it was fine....but every now and then at idle it sounds like i could here blow by or lil puts....and welll lastnight i was going to work and it got worse but this time it aint getting any better i checked the comp and got
cyl1-190
cyl2-150------got 190 after adding tranny fluid to the cylinder
cyl3-190
cyl4-190
if i hit the gas it breaks up at like every rpm.
now i believe i have to rip this mother out to replace the rings....i was first under the impression that the vafc might have screwed with things but now lookin like rings or valves
plugs are good
wires are good
has anyone had a similar prob ....help me out
cyl1-190
cyl3-190
cyl4-190
plugs are good
wires are good
i checked the resistance on the wires and were all about the same... and the plugs seem to be ok....brown with strong spark....but u really think that comp is ok.... cuz the car is superweak, takes forever to rev high and sounds like ****.....exhaust sucking in and blowing out....not burnin oil tho
