Can u tuned a car with its stock ecu
i have an 95 LS with a stock OBD1 ecu not sure what type of ecu it is for my model. but i did a few mods and bold on it like cold air intake, hearder, exhaust, cam, valve and spring, MSD ingition, light wieght pulleys. ect but i havent done anything to the ECU and i was wondering if go get it tuned for all my mods with its stock OBD1? or do i have to get a stand alone ECU..
OBD1 can be chipped, so no need for a stand alone.
And even a 100% stock car can benefit from a tune. Each motor runs slightly differently, especially with some wear and tear on it, but each stock ECU runs the same tune. Dialing in the ECU for the exact engine will result in better power, mileage, and reliability.
i agree even a stock car can benefit from a tune...headers, cam, intake, exhaust... you might be running a little lean... your moving more air... search ebay for or craigslist for a stock P28 computer, then find a decent tuner...someone who has a bit of car under there name..also dont buy into pre-tuned chips..you might as well **** your money away
so yes, op, you should get it tuned, i'm sure you'll gain at least a few hp.
thanks u guys for the input cuz i wanted to know if i could tune it or reflash my stock ecu. but like what chipped do i get... and i need the chip my ecu to retune or reflash it
I always try to stick with external or piggy back ECU's because if you jack up tour ECU your car is down until you can find a replacement but if the piggy back gets jacked you can just pull it out...unless you blow up your motor hahaha
FYI GET CROME!!!
GET IT HERE http://forum.pgmfi.org/
Inexpensive and completely customizable even at a local tuner shop.
FYI GET CROME!!!
FYI GET CROME!!!
FYI GET CROME!!!
no, don't get one of those "pre-tuned" ecu's. get your ecu socketed and chipped, and have it tuned by somebody who knows what they're doing. with those ebay chips you'll probably lose power.
FYI GET CROME!!!
FYI GET CROME!!!
what exactly do you mean by "external or piggy back"? in order to use crome you have to socket and chip the original ecu.
External or Piggyback like a greddy emanage or hondata in this case. Crome is just an alternative to sending your ECU off to someone. Its also cheaper and more easily modified at a shop or home because the software is free. Sorry I didn't make that clear before.
DO NOT BUY A PRETUNE ECU OR CHIPSET
chipping your ecu is a better way of tuning than through a piggyback. as far as i know crome can do everything hondata does, except the software is free. and yes, you're right, if you have the tools and knowledge to solder with you can buy the parts and do it yourself without mailing your ecu out. i chose to mail it out just so i can be 100% sure it's done correctly.
External like the AEM EMS, or Greddy E-manage or E-manage ultimate the two you mentioned are for monitoring and tweaking your AFC not engine tuning, though they help.
Hey found this if you got the $$$ this would be safe haha
http://www.horsepowerfreaks.com/part...300_OBD2/14676
All pre-assembled HONDATA ECU
fyi: the aem ems is a standalone, while the greddy e-manage is a piggyback. 2 completely different things. what's an afc? a/f controller?
to make it all easier on yourself... get the ECU chipped with hondata. And if you dont want to send your ecu out and need a spare. Either the p-75 or the p-28 will work because any good tuner will know to turn v-tec off with the p28 (which the hondata allows you to do). This also keeps you ready if you decide to do ls-vtec anytime soon. You wont have to get it chipped again just retuned. Stay away from standalone on that set up. And chrome works off of mostly basemaps which differs it from hondata.
