Hondata Boost Control Solenoid
Old Apr 8, 2009 | 01:52 PM
00si2's Avatar
Default Hondata Boost Control Solenoid
I've been searching around for quite some time and cant find anything on what I'm looking for.
I am trying to find how to wire a Hondata boost control solenoid. I've found the diagram from the Hondata website but don't know what to do with the wire thats supposed to go to ECU A11. And i believe a 12v switched source is just something that turns on and off with the ignition, correct? Can someone point me in the right direction?
Also, while i was searching i came across someone talking about having a hi/lo switch along with boost by gear using Hondata S300 and the boost control solenoid but they didn't go into much detail. What's involved in getting that to work?
Old Apr 8, 2009 | 02:10 PM
jdm inc's Avatar
Default Re: Hondata Boost Control Solenoid
one wire will go to a11 and the other wire will go to a 12v switched i dont think it matters which wire is which.
Old Apr 8, 2009 | 02:26 PM
champLSinteg's Avatar
Just like you said...With the two wires coming from the solenoid, one goes to 12v switched and the other to A11.
Old Apr 15, 2009 | 08:17 AM
00si2's Avatar
Does the wire going to a11 get spliced in or doesn't it make a difference?
Old Apr 15, 2009 | 01:57 PM
sq_creations's Avatar
you usually have to add a pin to the plug at A11. If the wire exists cut it and connect your boost controller.
ESP.net
Engine Management and Tuning
10
Apr 13, 2015 03:41 PM
ryguy2588
Aug 19, 2011 12:18 PM
slowlittlewhitey
Apr 19, 2010 09:14 AM
portenio78
Mar 12, 2010 11:03 AM
10sec4door
Feb 5, 2010 08:46 AM
