b18a1 into 1998 dc2?
Old Apr 8, 2009 | 01:11 PM
ieathonda's Avatar
Default b18a1 into 1998 dc2?
I have a b18a1 laying around at my dads shop and was wondering if i could throw it into a dc2 shell with minor work?
Old Apr 8, 2009 | 08:26 PM
vinskint's Avatar
Default Re: b18a1 into 1998 dc2?
What year is the B18A
Old Apr 9, 2009 | 06:43 AM
sixfourkiller's Avatar
if its a 92 or 93 it should be easy cause that run on ODB 1 but why what wrong with the engine it had now cuz your downgrading if u do that.
Old Apr 9, 2009 | 07:40 AM
Zappythebum's Avatar
He said if he threw it into a "dc2 shell", which means it has no motor currently
but yeah if its an OBD1 you shouldnt have many wiring or compatability issues
Old Apr 9, 2009 | 08:33 AM
HondaTom87's Avatar
and as far as downgrading goes just get the 96-2001 ls cams and you will be right where you want to be as far as power goes
Old Apr 9, 2009 | 09:24 AM
ieathonda's Avatar
those cams will make that big of a difference? and yes its from a 92 da integra.
so i heard the mount smay have to be switched around but what about the wiring? since its obd1 then it will all just plug up fine?
Old Apr 9, 2009 | 09:46 AM
HondaTom87's Avatar
yeah it will just be plug and play and none of the mounts should have to be changed unless the shell had an automatic in it...
and yeah those cams have higher lift longer duration on both intake and exhaust...
You may need to swap over the later model intake manifold as well but I would just get a blox or skunk2 intake manifold instead of worrying about that
Old Apr 9, 2009 | 10:35 AM
sp00ledbseries's Avatar
Originally Posted by HondaTom87
yeah it will just be plug and play and none of the mounts should have to be changed unless the shell had an automatic in it...Wrong the drivers side mount has to be changed out. Also the hydro tranny mount will not work on the cable tranny.
Old Apr 9, 2009 | 10:40 AM
HondaTom87's Avatar
did not know that thank you for the clarification...
This why I hate hydro trannys lol...
Old Apr 9, 2009 | 12:15 PM
ieathonda's Avatar
drivers side engine mount and tranny mounts will have be swapped out correct? and axles too, which i already have. should just drop in with minimal eletronics involved (besides just plugging up ecu and wires) correct?
pub
Mar 13, 2015 09:12 PM
b18cls1
Mar 23, 2010 05:45 PM
