Less Power after Replacing O2 sensors?
Old Apr 8, 2009 | 12:59 PM
truazn4lyfe's Avatar
Default Less Power after Replacing O2 sensors?
Last month I replaced my O2 sensors in my 98 Gsr so I could pass inspection. Before replacing them I only had the primary sensor in with an odb1 ecu. The secondary o2 sensor hole was plugged. Now that I have passed inspection I have put the odb1 ecu back in and I left the secondary o2 sensor in and my car feels alot more sluggish. I replaced my o2 sensors with denso non-universal ones. I was just wondering why my car would be making less power?
Old Apr 8, 2009 | 08:33 PM
sixfourkiller's Avatar
Default Re: Less Power after Replacing O2 sensors?
well with i learned is that with OBD 1 ecu its should only read one of your O2 sensor and that the one in front of your cat and not until OBD 2 when it had more then one and it would read the O2 sensor from the back of your cat.. i recommend just take off the second O2 sensor if your still running an OBD 1 just your ecu doesnt used that back one unless your have an OBD 2
Old Apr 8, 2009 | 08:43 PM
papaboy's Avatar
Or your ECU has reset and needs to learn your driving style again
Old Apr 9, 2009 | 07:33 AM
Anyone else? Help?
Old Apr 9, 2009 | 12:12 PM
Top Speed's Avatar
How do you know it is making less power, have you dynoed it?
Old Apr 9, 2009 | 02:23 PM
i think u just can feel it when your car not running like it should like night and day when u run your car at night with a cold air intake u can feel it more then when u run it in the day and its only a few more horses
boosted civi
Mar 10, 2009 07:15 PM
NightHawkBlack-R
Feb 16, 2009 10:28 AM
HONDA RR
Sep 16, 2005 03:53 PM
opto_isolator
Mar 27, 2004 05:37 PM
gtpilot
Dec 12, 2002 12:27 PM
