b18c5 turbo or all motor
Old Apr 8, 2009 | 11:53 AM
jimmy051702's Avatar
Default b18c5 turbo or all motor
looking for a cost effective build all motor or turbo which is better and which is cheaper thanks
Old Apr 8, 2009 | 11:59 AM
Whatever's Avatar
Default Re: b18c5 turbo or all motor
What is your HP goal?
Old Apr 8, 2009 | 12:01 PM
umm turbo around 350 400 and all motor 200 or so somethin to run 12's or so
Old Apr 8, 2009 | 12:10 PM
Schister66's Avatar
Man U FTW
If you lower your goals a little for the turbo setup, you could easily hit it on the stock block. Currently, your goals are pretty high unless you have access to E85 or plan to run 100+ octane.
My suggestion would be to locate a GT3255e, SLS mini-ram and a full 3" exhaust. Tune that on ~11-12psi and you should be in the 325-340whp range. That will be enough power to be fun on the street yet safe on the engine. I have a dyno of a similar turbo (GT3255b) on my stock GSR @ 315/216 if you want to see the potential powerband.
Old Apr 8, 2009 | 12:51 PM
hmm that sounds pretty good actually man how much did the setup run u?
Old Apr 8, 2009 | 01:16 PM
marcj's Avatar
you're in the forced induction section asking if you should go NA?
haha, I've built one NA car. CRX HF w/ 12:1 b16a.
never again will I build a car without some type of boost
Old Apr 8, 2009 | 02:46 PM
Ls_dx's Avatar
Old Apr 8, 2009 | 02:57 PM
Top Speed's Avatar
turbo for sure
Old Apr 9, 2009 | 08:02 AM
EL TYPE R's Avatar
im in the same situation but I am going Turbo. how many pounds are safe on a B18C5 Type R.
Old Apr 9, 2009 | 08:17 AM
Mag00n's Avatar
SEARCH
there is no set 'pounds that are safe' for any motor. 10psi on a 16g will give you much less power than 10psi on a gt35r.
It all about the tune and the power output, not the psi. B18c5 especially needs a good tune since its high compression.
Old Apr 9, 2009 | 08:33 AM
EKris's Avatar
Originally Posted by Mag00n
SEARCH
x344987579353
Old Apr 9, 2009 | 08:52 AM
HiProfile's Avatar
The cost-effective NA way would be to sell the C5 and build a C1. You'd end up with the same amount invested with a piston/rod/cam C1 as you would a stock C5. The problem is its still NA, and you need a lot of fine-tuning for 12's.
A stock C5 would handle 300 all day and 400 at the track. However, its still more cost-effective to use a piston/rod C1. A stock Z6 head can make 420whp (research EPIC HATCH), so a C1 head can make more than you need.
If you really want a C5 as a badge of honor, you might want to read a couple FI books like Maximum Boost before you take the plunge.
allmotorsleepingcivic
May 15, 2006 08:30 PM
matto2413
Feb 4, 2005 02:52 PM
Darksoul
23
Dec 16, 2003 03:47 PM
teg_girl
May 18, 2003 02:02 AM
InfamousRS
Jan 16, 2002 06:17 PM
